voodoogsx
- 323
- 10
- Jun 2, 2004
Sherman Oaks,
California
So I've had an on and off no start (turn the key and the car cranks but doesn't start). I thought it was my fuel pump as I could usually fiddle with the wires for the relay (did relay mod) and it wouldn't have an issue for a while.
I recently had to replace my water pump as it was sounding like it was about to die and now I'm finding I'm running into the no start all of the time.
I started with checking for spark (it's there), fuel pump (it turns on, I can hear it going when I enable it in DSMLink, plus checked when turning the key and tested the original relay) I checked the injector signal wires and get signal there. I checked the signals for the cam and crank, all there.
So here is the one thing though that I noticed and is causing me some worry. https://www.dsmtuners.com/threads/how-to-diagnose-a-no-start.217951/
In the section "Verify ECU operation " it notes, "also watch the stock boost gauge, the needle should move halfway up the gauge." When you turn the key to ACC.
Now, before I even crank the car this tells me if the car will start.
If the needle doesn't move, the car won't start, if it does move to the halfway point, it will start.
In the no start case, the CEL stays on, but I can't seem to connect to DSMLink when thats the case. But when the boost gauge does move, I can connect.
secondly, if the needle moves up, I also hear a whirring/bzzzrrrrr sound for about a second or so, not sure what it is, it's always been there it sounds like something is being set, like something moving almost like a loud servo but more metallic.
I've looked to see what this gauge movement is suppose to mean, but all I get is everything in the world about how not to trust the boost gauge.
