tsiawd90
Supporting Member
- 101
- 22
- Nov 16, 2017
Houston,
Texas
I need some help here I am stumped.
I bought a non running 1990 Eagle Talon, I have replaced the motor, fuel pump, clutch and turbo. I have everything that I can see hooked up.
The check engine light comes on for 5 seconds and goes off the boost guage goes up half way and stays.
I have swapped the ECU, I have checked the CAS position. I have checked my fuses. Nothing seems to change.
Looking for other things I should replace, check or inspect.
No start, no spark and no fuel from the injectors. I have fuel to the rail. I have a coolant light that is coming on.
Maybe I should check the CTS? Is there a way to bypass the sensor to see if that is the problem before replacing?
