1. Join the Community!
1G No Start - No Spark, No Fuel
Posted by tsiawd90, Jul 2, 2019
Please Support Feal Suspension
  1. tsiawd90
    tsiawd90 Supporting Member
    92
    20
    Joined Nov 16, 2017
    Houston, Texas
    I need some help here I am stumped.
    I bought a non running 1990 Eagle Talon, I have replaced the motor, fuel pump, clutch and turbo. I have everything that I can see hooked up.
    The check engine light comes on for 5 seconds and goes off the boost guage goes up half way and stays.
    I have swapped the ECU, I have checked the CAS position. I have checked my fuses. Nothing seems to change.
    Looking for other things I should replace, check or inspect.
    No start, no spark and no fuel from the injectors. I have fuel to the rail. I have a coolant light that is coming on.
    Maybe I should check the CTS? Is there a way to bypass the sensor to see if that is the problem before replacing?
  2. motomattx
    motomattx Proven Member
    2,206
    850
    Joined Dec 9, 2010
    wampum, Pennsylvania
    Cts has nothing to do with spark, find out why that is missing first, starting with checking power and ground at the cas.
    Drag Race Build 3K  24
    1995 Mitsubishi Eclipse GST
    fwd · manual · 2G DSM
    Loading...
  3. steve
    steve DSM Wiseman
    12,801
    576
    Joined Feb 3, 2002
    St. Charles, Illinois
    Are you sure that all the connectors are plugged into the right places? I seem to remember that there are two on a 90 that can be switched and the car won't start. I forget which one.
    I'd start by getting out my multimeter and makeing sure that there was power to the ignition and injector harnesses and look at why the ECT light stays on.
    4K  0
    1991 Mitsubishi Eclipse GSX
    manual · 1G DSM
    Loading...
  4. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    5,069
    2,420
    Joined Nov 14, 2013
    Independence, Kansas
    Steve is right that there is another plug that the CAS will plug into that is the wrong plug in the harness on the passenger side. I can't remember which plug it is either, and I HAVE a 90 (but it's been down for well over a year). Make sure that the CAS is in the correct connector, look around the engine bay for another open end plug that the CAS can plug into and give it a go.
    Street Build 4K  28
    1992 Eagle Talon TSi AWD
    14.74 @ 117.04 · 1G DSM
    893  14
    1990 Mitsubishi Eclipse GSX
    awd · manual · 1G DSM
    631  18
    1967 Chevrolet Camaro RS
    rwd · automatic · Misc Vehicles
    Street Build 855  7
    1998 Eagle Talon TSi
    Street Build 6K  13  25
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 · 1G DSM
    Loading...
    tsiawd90 likes this.
  5. jim95redgsx
    jim95redgsx Proven Member
    88
    46
    Joined Jan 26, 2005
    Melbourne, Florida
    The ECT light has nothing to do with starting the engine, There are two sensors on the thermostat housing. The 2-wire sensor tells the ECU what the engine temp is. This can affect starting. The 1-wire sensor controls the light. This light will turn on when the key is switched to ON (as a bulb check) and will remain on until the engine is started (until the alternator voltage exceeds the battery voltage).
    steve likes this.
  6. galant_martin
    galant_martin Probationary Member
    9
    Joined Aug 15, 2013
    Austria, Europe
    Isnt CAS and TPS the same connector ? 4 Pin Type ?
  7. 1990TSIAWDTALON
    5,069
    2,420
    Joined Nov 14, 2013
    I believe so but a quick check of the TPS signal would verify if it is plugged in to the correct connector.
    Street Build 4K  28
    893  14
    631  18
    Street Build 855  7
    Loading...
  8. steve
    steve DSM Wiseman
    12,801
    576
    Joined Feb 3, 2002
    I do know that the colors of the wires in the two connectors are different so comparing them to the wiring diagram would identify the error quickly.
    4K  0
    manual · 1G DSM
    Loading...
  9. galant_martin
    9
    Joined Aug 15, 2013
    Austria, Europe
    I don’t know if im correct now, but 1G TPS only has 3 wires in the connector/ TPS 4?
  10. steve
    steve DSM Wiseman
    12,801
    576
    Joined Feb 3, 2002
    4K  0
    manual · 1G DSM
    Loading...
    1990TSIAWDTALON likes this.
  11. AllanL
    AllanL Proven Member
    269
    22
    Joined Apr 24, 2008
    LV, Nevada
  12. tsiawd90
    92
    20
    Joined Nov 16, 2017
    Houston, Texas
    This could be the problem. This is the connector that i plugged the cas into, does this look correct?
  13. tsiawd90
    92
    20
    Joined Nov 16, 2017
    Houston, Texas
  14. tsiawd90
    92
    20
    Joined Nov 16, 2017
    Houston, Texas
    Thanks, that rules that out so I can focus on other areas.
  15. steve
    steve DSM Wiseman
    12,801
    576
    Joined Feb 3, 2002
    I can't tell from that picture. (The FSM implys the connector sex is different between the CAS and TPS so I'm not sure you can swap these.)
    The 1990 Car Harness for the CAS will have Black, Red, White, and Black wires
    The 1990 Car Harness for the TPS will have Green, Green/Black, Green/Red, and Green/White wires
    WRT the 6 pin connectors on the ISC and Resistor Pack.
    The 1990 Car Harness for the ISC will have Blue, Red, Yellow, White, Red, and Black wires.
    The 1990 Car Harness for the RP will have Black/Yellow, Open, Red, Black/Blue, Black/White, and Black/Red wires.
    On a 90, the wiring harness connector for the TPS is 4 pins. The pigtail that plugs into it has 3 three wires running to the attached TPS and 1 wire to a connector for the IPS.
    4K  0
    manual · 1G DSM
    Loading...
  16. 1990TSIAWDTALON
    5,069
    2,420
    Joined Nov 14, 2013
    I'm 99% sure this is the connector location
    Street Build 4K  28
    893  14
    631  18
    Street Build 855  7
    Loading...
  17. steve
    steve DSM Wiseman
    12,801
    576
    Joined Feb 3, 2002
    The one next to it looks like it's for the TPS but has a 90-2G TPS adapter attached?
    4K  0
    manual · 1G DSM
    Loading...
  18. 1990TSIAWDTALON
    5,069
    2,420
    Joined Nov 14, 2013
    Yes it does Steve. I just can't hack up a good harness.
    Nice spot though.
    Do you think that is the correct connector for the OP? That car has been "under reconstruction" for well over a yr.
    Street Build 4K  28
    893  14
    631  18
    Street Build 855  7
    Loading...
  19. steve
    steve DSM Wiseman
    12,801
    576
    Joined Feb 3, 2002
    For the CAS connector. That would be my guess but I'm doubting that you can swap the TPS and CAS connections. Like in your picture the harness connectors are both 4 pin but the connector sex is wrong, so you could mistakenly plug the two harness connectors into each other but you couldn't plug the CAS pigtail into the TPS harness or vice versa.
    So I'm wondering what question we are trying to answer?
    4K  0
    manual · 1G DSM
    Loading...
  20. 1990TSIAWDTALON
    5,069
    2,420
    Joined Nov 14, 2013
    Thinking since the OP had no fuel or spark that he could have plugged the CAS into the wrong connector on the harness.
    Thanks for the help Steve!
    Street Build 4K  28
    893  14
    631  18
    Street Build 855  7
    Loading...
  21. tsiawd90
    92
    20
    Joined Nov 16, 2017
    Houston, Texas
    How do I test to check the cas and tps connections? Do I check it at the ecu or can I check the from the connectors?
    Monday I will be looking at it again hopefully I can find the problem.
  22. steve
    steve DSM Wiseman
    12,801
    576
    Joined Feb 3, 2002
    When you engage the starter does the tach read anything?
    If you turn the CAS by hand with the ignition on does the fuel pump start running?
    Do you have a datalogger? A multimeter?
    BTW, the radiator warning light in the cluster is for the overflow bottle. It's on when the bottle is empty. I've had to flush mine out several times over the years to free up the float switch and get it working.
    4K  0
    manual · 1G DSM
    Loading...
  23. tsiawd90
    92
    20
    Joined Nov 16, 2017
    Houston, Texas
    I'll check the tach I cant remember if it was moving. Aslo will try hand cranking the cas. I do know fuel is going to the rail.
    I have a multimeter will buy a datalogger if necessary.
    I'll look at the over flow sensor as soon as I can get it started. I'll try your flush when I get to that. What did you flush it with?
  24. steve
    steve DSM Wiseman
    12,801
    576
    Joined Feb 3, 2002
    Lots of soap and hot water...
    There are two ways the fuel pump runs on a 1G DSM.
    The first is via the signal to the starter and the second is via the ECU seeing the CAS turn. Using the starter is usually how you make the second happen and that's what keeps the pump going until you stop the engine. About 5 seconds after the last CAS pulse the ECU times out and turns off the pump.
    So don't hit the starter, if the pump turns on when you turn the CAS you'll know the ECU saw something from it.
    4K  0
    manual · 1G DSM
    Loading...
  25. tsiawd90
    92
    20
    Joined Nov 16, 2017
    Houston, Texas
    Problem solved, the harness connectors were plugged into each other and the sensors were plugged into each other. Looks like when they put the engine in they plugged together the two sensors then the connector ends where both left next to each other so they were then plugged into each other.
    Still have some other issues to work out but glad this one is solved. I've got some misfire and some oil leaking from the lower timing belt cover. Maybe this week will be the week.
    Thank you everyone for all the help just glad to be moving forward and not stuck on this problem.
    Dezentdan, 1990TSIAWDTALON and AllanL like this.
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
