femmeDSM
- 980
- 68
- Oct 31, 2004
D/FW,
Texas
Just got my car running last week, and am now in the process of diagnosing all the new problems that have come to light
Most importantly, the car will not go into reverse AT ALL. Will (usually) shift into 1-5 fine, but not always. In fact, the only relatively consistent gear is 5th.
Here is what each gear is doing:
Reverse: When I try to shift into reverse, the shifter will go all the way back into the reverse position, but as soon as I let off the handle, it will just glide back into neutral, slowly. I have never been able to get it to click into gear, and have tried everything I can think of (shifting from 1st to reverse, 5th to reverse, starting in reverse, holding the shifter in place, etc.). It just won't go.
First gear will come and go as it pleases. I either need to slam it into gear with all my strengh, or put it in gear and slooooowly roll forward until it starts to grind, then it will go into gear smoothly. It's very annoying. Other times, it will shift just fine, although it always takes a bit more muscle to get it into gear than I am used to w/ other DSMs.
Second has a mind of its own, too. Whenever I lose first, I sometimes will just have to start it in second (like if I'm at a light, and have no time to baby it into 1st). The other day, though, second just decided to take a crap for 2-3 shifts, then came back like nothing had happened. The times it was missing, when I shifted into second, the shifter just slowly moved back into neutral, similar to what reverse does.
Third is usually okay. I have grinded it before, though (and I am a VERY good driver, and have never had ANY problems driving other 5spds, so it is not me, it's definitely the car). It will feel like it goes into gear, but when I let off the clutch, the car will bog, and when I give it gas it will slip, then grind. I have to push the shifter forward another 1/4 inch or so, then it will Click audibly and will be in gear.
Fourth is decent. Does the same thing as third sometimes, though (have to click it back into gear twice or it will grind)
Fifth is actually okay. I don't know why. It is my least-used gear, as I have been trying to keep my car off of main roads. I have used 5th maybe 4 or 5 times, and have never had a problem getting it to engage or stay put.
So basically...What are the chances that ...
A) I have a stupid problem, like shifter linkage/bushings/etc.
or
B) I am looking at a transmission rebuild
By the way, in case you don't read my Vehicle Profile, the car has an ACT2600 clutch and flywheel installed (approx 10K miles). I bought the car with the clutch installed. I have NO IDEA if the transmission has ever been out of the car, but I do know that the engine (top and bottom) was rebuilt at or around the same time the clutch was installed. I have receipts for most of this, and trust the person that did the installs (not the person I bought the car from, who I wouldn't trust as far as I could throw).
or
Always glad to have you around when I have a new problem,
I'm taking everything I've heard about the car w/ a grain of salt, at this point.
However if you have any more questions feel freee to ask. I will help you in any way I can since I have a 90 bastard child
