sniver
- 764
- 25
- Feb 13, 2006
Leetsdale,
Pennsylvania
they all have power. so why isn't it working.
Check continuity between ecu oins 8,38,12,&24 and there respective mpi/fuel relay plug pin locations.
if that checks out, try the other ecu.
Options are relay,ecu,or wiring between the two if you do in fact have power everywhere thats required.;
Check for a broken wire in the harness if you haven't checked it yet. Sniver Knows I had a similar problem and to find there was a broken wire.
I linked him to that post once, described it, and similar situations. he ended up replacing the original harness with another used untested condition harness, and believes there to be no flaws to it that he is aware of.
Well despite he has a 95 harness and had to custom wire the relays.
Will you just fix this poor dsm already, I'm long grown tired of checking in with the wife(you/your car) everyday to hear her new issues. .....
I'm just kidding, your almost there, I mean it ran, that has to be awesome after all this , right?!
