No Boost
95AWD6Bolt
504
Dec 2, 2006
South Jersey, New Jersey
Finally got my car back together after installing a PTE 50 trim. Had to fix a few oil leaks but that is all tidied up now. I go to drive it and the car wont boost at all. The gauge goes to zero and then nothing after that. Im lost and dont have any idea of where to go from here.
6 bolt block 2g head
pte 50 trim(FRESHLY REBUILT) Being fed from the head.
tial 38mm wg
fmic
880's
walbro 255
halman mbc
ngr type s bov
3" tbe
fp 4" intake
I have a brand new pcv valve as well, not sure if that would help or not.
I would probably verify all your vacuum lines are in proper location. As well as the boost leak test. You could change where you have the boost gause plumbed to to right off the turbo to see if it is boosting right there rather then to say manifold.
vacuum lines are hooked up via a diagram that I found on here while searching. I am going to double check them and my mbc tomorrow. Also am going to make a blt and see if I have any leaks. From there, I am going to check the bov and wg. Ill keep you guys updated.
