kiri
- 41
- 0
- Feb 6, 2012
clarksville,
Tennessee
My t25 took a dump on me 2 days after buying a Talon so I wanted to do some upgrades. I did these upgrades all posted below and installed the new big 16g and started the car just to make so I wasnt having the same issue as I was before with a blown t25. The car idled after a little squeeking from the oily belts. But it idled.
I gave a little throttle to check to see if it was making boost and it was NOT. :-/ I searched and searched, I checked and checked (vaccum lines, leaks, fluids, etc etc) and no luck. So here I am..
95 Talon Tsi Awd 7 Bolt with
Exhaust headers, Apex 3in downpipe, megan 3 inch exhaust, ported o2, aftermarket whatever uic pipping, SAFCII, stock injectors(evo560'a not installed yet), stock pump, (255 not installed yet), autometer boost, oil press gauges, Halman MBC(8-10 psi on my troubleshooting start up),Blitz turbo timer, dejon style Intake Pipe, KN filter, new upstream 02, Big 16G, 16G install kit, hacked oil return pipe, Free mods-honey combs out, screw backed flush, and can't think of anything else right now.
So the issue is What am I missing? Did I overlook something to check on why I am not producing boost?
Side Note I had a lil exhaust back fire..Not sure how in the world I would be running rich on 450's with a big16g. But anyways I believe that is all the info I can think of as of right now. If more info is needed I will be checking this every few hours of the day for the next few days. Thanks in Advance and I am sorry if I posted this in the wrong area.
I gave a little throttle to check to see if it was making boost and it was NOT. :-/ I searched and searched, I checked and checked (vaccum lines, leaks, fluids, etc etc) and no luck. So here I am..95 Talon Tsi Awd 7 Bolt with
. Everyone has to learn sometime.
