AWD-Tony
- 6,787
- 3,746
- Sep 11, 2017
Cincinnati,
Ohio
Just went to pick up some groceries and videos a pull. Didn’t bring my laptop so no log. I just noticed my afr’s were lean af at the beginning of 3rd. I’ve done pulls from 3-8k and they’re pretty dialed in. This can’t be normal?
. Took it out for a cruise and I'm pretty sure it's the WB or sensor. Once it goes full lean (off throttle) then go back on throttle, it's really lazy. The range of laziness varies as you can see from the log. Will try calibration first, and try the old sensor if that fails.
