1. Join the Community!
New to the forum world...
Posted by Mask S, Oct 23, 2019
  1. Yes. Change filter
    1 vote(s)
    100.0%
  2. No. Check fuel pump
    0 vote(s)
    0.0%
Multiple votes are allowed.
Please Support ExtremePSI
Please Support Feal Suspension
  1. Mask S
    Mask S Probationary Member
    Joined Oct 23, 2019
    Garden Grove, California
    1st Eclipse 3g 2002 GT, currently have a 2g 1998 Spyder GS w/automatic. 20190628_054609.jpg
  2. BLACK'98DSM
    BLACK'98DSM Proven Member
    879
    281
    Joined Feb 9, 2019
    Hoover, Alabama
    The filter is easier and cheaper than the pump, so try it first.
    And before you mess with the pump test your fuel pressure.
    Road Race Build 2K  25
    1998 Mitsubishi Eclipse N/T
    fwd · manual · 2G DSM
    340  3
    2012 Murray Explorer Dune
    rwd · automatic · Misc Vehicles
    257  6
    2009 Troy Bilt Bronco
    Loading...
  3. BLACK'98DSM
    879
    281
    Joined Feb 9, 2019
    Hoover, Alabama
    Also, what makes you think it's a fuel problem? Why not spark?
    340  3
    257  6
    Loading...
  4. Mask S
    Joined Oct 23, 2019
    Sorry for the delayed response. After stalling, mostly on the freeway, it starts then dies immediately as if it's out of gas. It will however keep starting & dying. After it sits a while it will start & run ok again. Could it be the crank sensor giving a faulty temp reading?
  5. BLACK'98DSM
    879
    281
    Joined Feb 9, 2019
    Hoover, Alabama
    The crank sensor does not read the temperature, it reads the position of the crankshaft and sends that data to the ecu so the engine will run properly. I doubt it's the CAS, because sitting for a while would not have an effect on it.
    Does it ever run hot? Or does your temp gauge even work?
    340  3
    257  6
    Loading...
Share This Page
Archer Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory WheelWell.com
