Matt_sagun
- 2
- Oct 20, 2019
bristow,
Virginia
Hey guys! Newbie here to the DSM scene. Just picked up a 1999 GST for 2k with 122k miles automatic. Car runs decent, but trying to get everything replaced so that it can run better. Not modding at this point, just getting everything back to stock for now and running smooth. Everything is stock with the exception of the dodgy BOV (which was replaced with stock unit). Already started to break into it and already replaced a bunch of parts and the more I keep digging, the more things I am finding to replace...
- Aftermarket BOV changed back to stock
- Driver side door handle.
- Front Upper A-Arm suspension
- Front o2 sensor
- Rear lower control arms
- All suspension bushings
- Oil change
- Radiator Flush
- Fuel Filter
- brakes
- rotors
- Oil Cooler leaky O-Ring
- Oil and Filter
- Air Filter
- New exhaust manifold studs ( on broke off in the head)
- New exhaust manifold gasket
- New turbo Oil return line gasket
- Rear lift struts
- engine degreasing..LOTS OF IT..OIL IS EVERYWHERE.
- adjust belts that were to tight causing super loud sqeal
- Front o2 sensor
- Oil change
- Radiator Flush
- Fuel Filter
- brakes
- rotors
- Oil and Filter
- Air Filter
- Rear lift struts
