jazzyjay
- 216
- 0
- Mar 27, 2003
I am starting a new project it is a all original Galant VR4 that has been sitting in a garage for aleast 10 years. The car was parked after the timming belt pop and put a hole in one of the pistons . So now it starts a new life with me. My goal is to make a sleeper with only Mitsubishi bolt-on parts.
In the tear down so far I have discovered that the turbo was frozen. So now I get to spend some money I figured I buy the EVO 3 16g and O2 housing.
I want the best flowing exhaust manifold, that I can bolt the factory heat sheild to with little to no modification.
The injector size is not inportant because the ECU will be chipped. I will using a 190 fuel pump as not to over run the Mitsu fuel preasure regulator, or could I us the 255(will not be hot wired).
The block went to machine shop yesterday will find out what size pistons I need to buy today.
Is there a better Mitsu fuel presure regulator that I can bolt-on?
Is the other Mitsu parts that will bolt on and look factory that I am missing?
I have a 90 throttle body.
