EC17PSE
Freelancer
- 5,894
- 3,487
- Nov 1, 2008
London, UK,
Europe
LIST CLOSED!!!!!
install write up https://www.dsmtuners.com/threads/how-to-install-bobbys-4-point-front-underbrace.527731/
Hello Tuners and welcome to this item I am going to be making very soon!
This item was ment to be a 1 off for myself but I had quite a few people interested asking abut it over a few platforms as to if it will be sold so I decided to offer it up to you all!
We dont have many options for bracing and only Tanabe and RRE offer something for us and its only a 2 point brace.
So this brace is none like others, it connects to all 4 points of interest being the rear lower subframe mounting points and also connects the front lower arms together and then front to rear, This is a very strong brace and is very rigid in design vs the normal Tanabe front under brace. Ralliart once made a brace for the Galants but was not super strong and cost a fortune if you could find one!
SO WHY BUY AN UNDER CHASSIS BRACE???
Well the factory tried to stiffen the subframe up by adding plates and it helps but its not the best end result.
the subframe flex's still and a 2 point rear tanabe works well ( i used one for years and felt the difference) so connecting all 4 points is a great way to keep it more in check and add rigidity for a more precise steering feel.
connection of the front lower arms is not very well supported in oem so when cornering it will put load on these locations and incur small amonts of flexing,
These will be great for any driving from daily to racing to really stiffen up that front end more and improve handlng and feel.
I am going to cater for all models on this as I can adapt for it and test for it since I have 2 chassis to mock up against here.
The 2 versions will be available are
* 4G63 and 4G64 models (2.0 turbo and 2.4 N/A).
* 420A. version here https://www.dsmtuners.com/threads/n...r-brace-subframe-brace.526501/#post-153746630
the 420A crossmember and exhaust sit lower so will come as close to the cross member as my pictures show for the 4G engined chassis,
Just let me know which model you will require so I know what to make please.
will fit the GSX fine since nothing sits lower then the crossmember.
* Bushes are CNC machined for precision.
* Tubes are seamless CDS steel (very strong and light)
* 2 stage RED powder coated (zinc primed)
* New front hardward 12.9 socket capped bolts and nuts, (re use your old rear flanged subframe nuts)
This weighs in at 4.9 Lbs so its fairly light and very very strong.
Price is $310 shipped to the lower 48, Canada or any other locations please message me to check your shipping price as it may alter slightly.
You can either pay in full up front or do a deposit ($160) and pay the remainder when i close the list, the more i can get upfront the sooner i can get working on these and possibly have them built sooner and shipped sooner, so pm me with how you wish to proceed.
I would like to close this at the end of Jan 2020 and have them made and shipped by end of march 2020 or sooner If I can, I need at least 15 to start this going and If i get enough sooner I can perhaps start sooner with the process of metal ordering and getting to work on them
4G63/4 model.
1. @llxkevinxll P
2. @fredom dsm P
3. @DsmKhan P
4. @T2Small P
5. @rabenne P
6. @MindBlowin03 P
7. @Eclipse 1998 P
8. @josh408 P
9. @tunernewb92 P
10. @ames905 P
11. @my98gsx D
12. @mitsumikey X2 P
13. @calgst95 P
14. @crazy95dsm P
15. @Christian Helsel P
16. @b00st3d D
17. @bluespunk P
18. @Andreb P
19. @DSM98GSX P
20. @mountain_man P
21. @TommyDSM P
22. Kie P
23. @efrainz28 P
24. @Verdant P
25. @ARoseGsx P
26. @Black95TSIawd P
27. @96dsmftw P
28. @victor aguilar P
29. @rival P
30. @181161 D
31. @Deve
32.
420A model
1. @dsmcrzy P
2.
4G63/4 model.
1. @llxkevinxll P
2. @fredom dsm P
3. @DsmKhan P
4. @T2Small P
5. @rabenne P
6. @MindBlowin03 P
7. @Eclipse 1998 P
8. @josh408 P
9. @tunernewb92 P
10. @ames905 P
11. @my98gsx D
13. @calgst95 P
14. @crazy95dsm P
16. @b00st3d D
17. @bluespunk P
18. @Andreb P
19. @DSM98GSX P
20. @mountain_man P
21. @TommyDSM P
22. Kie P
23. @efrainz28 P
24. @Verdant P
25. @ARoseGsx P
27. @96dsmftw P
29. @rival P
30. @181161 D
31. @Deve
32.
420A model
1. @dsmcrzy P
2.
