Shinko
- 1
- Oct 20, 2011
Wadsworth,
Ohio
Buyer pays shipping or you pick up. Factory stock, front wheel drive, 5 speed, turbo, four cylinder car. Garage queen. The only concession from stock is the sub woofers in the trunk. The subs are not bolted down, no mounting holes were made with there installation. If you do not want them. They can be removed with no tell tale sign they were ever in the car. They do go with the car however. The pictures show a maintenance log I have kept since I purchased the car used in February of 97. The big maintenance items - timing belt, clutch assembly, wheel bearings, water pump all dates and miles when renewed are shown on the log. The air conditioner compressor, dryer and condenser are new parts. Recharged using genuine DuPont R12 refrigerant. Ball joints, tie rods, all recently new. All lights, head light doors, electric windows, wipers, heater, release latches for hatch and gas door, automatic seat belts function as they should. The pictures show the Ohio EPA pollution tests from 1999 to the last mandatory one in 2015. The tests show the motor runs clean. Portions of the car have been repainted - hood, front fenders, doors above the rub strip, quarters, the black aero trim, half of the roof from the hatch forward. All looks original and very presentable. The leather faced driver's seat has cracking leather but, no rips or tears. Passenger leather faced seat is in much better condition with very little wear. Back vinyl seat looks new. The door panels, dash and back seat trim panels appear as new. A car you would be proud to drive and own!
The dirty appearance of the engine compartment sheet metal and back side of the hood is a Ziebart rust treatment. It certainly is removable with the right cleaners and time. It just never bothered me enough to remove it. It is original to the car from the first new owner.
Car comes with four re-manufactured rims mounted with tires. Four of the original rims in original condition (mounted on the car in the pictures) with mounted dry rotted tires only fit for storage and two re-man rims without tires. Included is a Covercraft WeatherShield HP custom fit car cover. Sure I used it. Worked good then, works good now. If you brought it new today it would be a 363 dollar cover!! Also
a nice collection of parts.Attachments
