Gmosiman
- 34
- 8
- Sep 2, 2021
Elkhart,
Indiana
Okay so back to the amateur questions. I bought 775cc FIC injectors, deatschwerks DW300 pump, and aeromotive fpr 30-100psi adjustable. I threw them all in when I put this engine together and put it in. No tune yet.. I was fully aware that running the car for too long without a tune with this stuff in was NOT GOOD. But I need it to start. I don't want to take it in to get a tune and an ecu if I can't even be sure it will start. So I've tried starting it. And the first few times I got it to fire, and even run for a second. Like literally a second or 2. But I had oil leaks so I've torn the car apart to fix that stuff. It's all back together, and I've tried starting it again. But this time, I'm getting fuel out of my exhaust manifold and the turbo has some too. So it's obvious I've flooded the cylinders and plugs but what other damage can this do??
I did unplug the pump and dry fire the engine to clean the cylinders. I always did this as a kid on dirt bikes but I figured this was okay because all I'm doing is cleaning the cylinders via the compression. Just a little worried that there is something I've missed while doing this
