pneumo
20+ Year Contributor
- 3,763
- 59
- Oct 19, 2002
Bay Area,
California
Great news! I put my car on the dyno today to see how the new mods and tuning were doing. Here's the dyno chart:
Yep, 597 AWHP on a Mustang dyno! I wanted to push it over 600, but it just wouldn't do it. I was at the limit of the MAP sensor at 36 to 37 psi of boost, at the limit of the 1000cc injectors at 100% DC, at the limit of the Walbro 255HP pump as seen by the lean area above 6000rpm.
I had no idea the car was making that much power. Seriously I though it would put down around 425 to 450 since that's about what it put down last year. All I changed since last time was a 2G head with EVO3 intake manifold and Kelford 272 cams with some nice Kiggly Beehive springs to back it up. I used to have a 1G head with a JMF SMIM and FP2 cams. Oh, and I replaced the 3 bar MAP sensor with an Omnipower 4 bar MAP sensor, so I was able to raise the boost from 28 psi to 37. I should've known it was making a lot more power when it started spinning all 4 tires in second gear during my pre-dyno tuning sessions! I mean I was literally getting sideways in second gear on dry straight roads in warm 65* weather.
Just for fun I turned the boost down to 29 psi to see how much power it was making compared to the 444 AWHP it made last year at 27psi boost. Here's the result:
So I made 89 more HP with gains at every rpm! The boost might be one or two psi higher, but it's still a large gain at nearly the same boost. I'd also like to say that I didn't touch the tune when I turned the boost down, I just unscrewed the Hallman MBC a couple turns and did one pull at that boost, so I'm very happy with my tuning software.
Mods
Custom Jackal program
GT35 journal bearing turbo
ETS fmic 31 x 12 x 3.5"
3" uicp
full 3" exhaust
2G head
Kelford 272 cams
Supertech valves, standard size
Wiseco 9.0 pistons
Eagle rods
I did all the work on this car, tuned it and built it.
I may be forgetting something, just ask!
Mods
3" uicp
full 3" exhaust
2G head
Kelford 272 cams
Wiseco 9.0 pistons
Eagle rods
