New Dsm car
quick_silver90
Jan 24, 2003
Hi,
I just resently got a 91 AWD Eagle Talon and I have a question about it. First the water temp gauge isnt working.
And I think the fans are not turning on too.
Can anyone help this dsmer out I'd aperate it!
Thank you,
Snag a manual for the car if you plan to work on it, that'll give you some steps for testing the fans. Could be a single fault is causing both problems.
probly your electrical connections are just coroded, check them and if they are file them off and then try it,had the same prob with a golf once.
After looking at the car the more the fans do work when I turn the ac on,
But I still have an issue with the water temp. reading on the cluster gauge. It still dosn't display any reading.
On question is the water temp gauge, (I know that there is 2 of them one for ECU and one for the gauge cluster) is where are sensors?
Thank you,
Shane
huh? that last bit made no since to me but if your asking where the temp gauge is located it's in the bottom passengerside of the radiator..
btw it takes ALONG time before it gets warm enough for the fans to come on if it's just ideling and then they only stay on for a moment..
Your coolant temp sensor is underneath your thermostat housing. It gives the ecu the reading for the temp guage. Check the resistance of it and compare it to the values in your manual, that will tell you if it is good or not.
  • For sale Jmf race manifold
    6 bolt jmf race manifold throttle flange is for s90 Asking $400 plus shipping
    • spoolinjuice
  • For sale 1g 1G EDM Taillights for sale
    • Shaxzy
  • Wanted 2g Front glass wanted
    Hopefully some has one or has a lead on one but im having a hard tome finding any
    • 2gRhino
  • For sale Dynatek ARC-2
    Dynatek arc-2
    • FWD
  • For sale Used Powder Coated Valve Cover
    Used Powder Coated Valve Cover Black texture with silver letters Was Powder Coated by someone...
    • mjboehm
