Please Support Morrison Fabrications
New clutch / now hard to shift / and lets out too fast
ninja07
51
Dec 7, 2009
antioch, Tennessee
I've got a 95 eagle talon tsi awd- I had a new clutch-flywheel-master-slave-and shifter bushings installed. When I got it back, it is hard to shift and it lets out very quick. When I'm letting out on the clutch and the car starts to move, about a half inch after that, it's done and rolling all the way. In other words, I have about 3/4" of play in the pedal until it's completely out. It bucks around and vibrates a little too. Feels like a little slippage as well. I hope someone can help before I ruin a brand new clutch.:confused:
Honestly, seeing as they replaced most things hydraulically, re bleed your slave cyl. I highly doubt the shop did it the proper way.
Slave Cylinder for the Clutch
That's how you bleed it. It should be pretty standard for 1g 2g.
Also, check the transmission through block bolts. They could have forgotten to tighten one down.
Best of luck!
