DeadsEvolution1
- 357
- 1
- Jan 10, 2008
Albuquerque,
New Mexico
Ok so if I can't fix this in the next week I'm selling this POS or blowing it the hell up.
Car will not idle. If it does idle it's at 500rpms and rough as hell. Also it will barely rev up past 3k at all. Thats nearly flooring it down to get it to rev up. Also it sounds like crap. If I hold it at 1500rpm's it sounds bad. Like it's missing or something. It's almost spuddering.
Thoughts on this:
1. Injectors are failing?
2. Not enough fuel getting in
3. 1 cylinder not firing
4. Timing off somehow although redone 3 times.
5. CAS way off (I adjusted it alot but not with a timing gun but still no help even If i set up the CAS way off it still idled terrible.)
6. TPS sensor off?
7. Could the Knock sensor cause any issues?
8. 02 sensor broken?
9. Any chance a fuse or something is blown causing issues??
Anyone and everyone please give me some insight. I am on tilt right now done with this f king car. Thanks
Thoughts on this:
6. TPS sensor off?
