1_vicious_gsx
- 118
- 0
- Oct 23, 2002
Sportsmans Para,
Louisiana
To GRNDSM, sorry about the highjacking.
1_vicious_gsx said:Wrong. :thumbdown
DSMLink is the ECU. There is nothing external about it. It's all in the ECU, just like the AEM EMS unit.
Yes I do own it, and yes I do use it.red91gst said:Do you actually own or have ever used DSMlink? It is a modified stock ecu. It still works off the same fuel and timing curves, your just modifing a stock curve. Granted, DSMlink is an amazing tuning tool and has some features that a stand-alone does, but it is NOT a stand-alone. It still relys on the stock ecu and still retains the stock maps.
Nate
SBR
1_vicious_gsx said:Yes I do own it, and yes I do use it.
My answer to his statement was that DSMLink is not a piggy-back. I never said it was a full blown stand-alone.
So I guess since DSMLink has the basic maps in it that allow anybody's car to idle or cruise around town that's a bad thing? WOT fuel tables, injector size, timing, etc are what anybody is tuning on an ECU, wether it's EMS or DSMLink.
A piggy back unit fools the ECU into doing something other that what it would do normally. AN OUTSIDE SOURCE for adjustments.red91gst said:Then what is a piggy-back? Is it not a unit that modifies the stock ecu/signal to allow for adjustment of the fuel/timing curve?
Nate
SBR
Do we really need to argue over what it is?
DSM Link is an ECU modification. Similar to what TMO did in the old days, but only much more advanced. And that was referred to as just: TMO ECU
Exactly.GRNDSM said:If anything, I would think of it more as a standalone ECU, which uses OEM hardware.
GRNDSM said:You guys are both wrong, it is neitherDSM Link is an ECU modification. Similar to what TMO did in the old days, but only much more advanced. And that was referred to as just: TMO ECU
You can still use Piggyback system with it (not that you would want to).
But, I do not believe that there is an official definition of what it is, so this is a useless argument.
What is the current setup you are running? Along with the daily driver aspect of it? A lot of people running the ems say that it does not make that great of a daily driver, and to stick with the dsmlink until you are ready to make it a full out race race
your thoughts?
