NEW! 1G Chromoly rear LCA's
99gst_racer
Moderator
11,976
1,542
Apr 5, 2003
Coloma, Michigan
You want them. We got them!
Chromoly 1G rear LCA's are finally in stock and available to ship! These are the versions that offer a double spherical sway bar connection. I have 5 sets ready to ship now and 7 more sets being finished. $360 + shipping.
These pair perfectly with our lightweight extruded upper arms! These will fit any AWD 1G DSM or GVR4.
Order here:
1G rear lower control arms: http://volkmetalcraft.com/product/1g-rear-lower-control-arms/
1G rear upper control arms: http://volkmetalcraft.com/product/1g-rear-upper-control-arms/
I thank you all for your continued support!! :dsm::talon::laser:
Sweet!!!
How is the height on the sway bar heim adjusted? Does the heim need to be disconnected from the sway bar and rotated to adjust the height? Thanks for offering these!
Sweet!!!
Great question. I utilize the same system on these as I have for the 2G LCA's for the past 6 years. It's a stainless steel adjuster that you adjust with a 15mm wrench from the bottom side. Just loosen the jam nut on top, makes adjustments from the bottom, and tighten the jam back up when you're finished. Piece of cake! The adjuster rides inside of a teflon-lined 3/4" monoball bearing inside the arm.
Hey guys,
I have 4 sets of the 1G lower rear arms (w/ sway bar hook-up) in stock right now. These have been flying off the shelf, so I just wanted to give you guys a heads up that they are available and ready to ship!
https://volkmetalcraft.com/product/1g-rear-lower-control-arms/
