NDgsx
DSM Wiseman
- 1,163
- 3
- Jun 10, 2002
Vancouver,
Washington
Mofugas just got these in from Whiteline in aus in June. They are polyurathane bushings with a eccentric (ie off center) metal sleeve. They replace the upper control arm bushings. You get another three degrees of camber adjustment with them according to Mofugas. Enough to get your camber back in spec no matter how low you go.
I put them in a friends car along with AGXs and H&R springs last week. Install is pretty easy. You unbolt the upper control arm and take it off the car (use a pittman arm puller or a small gear puller on the balljoint so you don't rip the boot). Burn out the stock rubber bushing with a torch (or have it pressed out). Clean it up, put the supplied lube on the urathane bushings, and slide them into the arm. Then put in the metal sleeve with a c clamp. Put some lube on the rear subframe and slide the arm in. Torque everything down and go get an alignment.
If you want camber back at factory spec put the metal sleeve in so that the thicker side will be going towards the inside of the car.
http://www.mofugas.com/mofugas.htm
KCA365
KCA365
