Rohitter7878
- 70
- 7
- Mar 12, 2022
Greeley,
Colorado
Found these two wires unconnected and was wondering where they go too, this is a 95 gst auto
Can anyone confirm this? Not sure where to post this since it was coming from the wiring with the transmission wires too. Is that needle?I think it’s for the boost solinoid
OK so I'm pretty sure it was removed then huh since the car I got has a manual boost controller..It’s for the boost control solenoid.
Yup. If you have ecmlink, you can install an electronic boost controller and control it through link.OK so I'm pretty sure it was removed then huh since the car I got has a manual boost controller..
OK, so it's not needed then?Yup. If you have ecmlink, you can install an electronic boost controller and control it through link.
If i recall 2g looks for it. You dont have to hook it up but i believe it still needs to be connected.If your running a mbc then no you do not need it
