1. Join the Community!
Need help with my 4g63t sand rail
Posted by Noel gonzalez, Oct 4, 2020
Please Support STM Tuned
Please Support Feal Suspension
  1. Noel gonzalez
    Noel gonzalez Probationary Member
    9
    Joined Oct 4, 2020
    Albuquerque, New Mexico
    Hey guys so i just bought this sand rail with a 6 bolt 4g63t that's not running right needs tuning i think it doesnt have the maf sensor i really dont know much about this engines. Is there some one here in Albuquerque that can help with tuning and getting it running right?
  2. Dericsh
    Dericsh Supporting Member
    578
    55
    Joined Nov 25, 2002
    Pearl River, Louisiana
    I think I see a 1g MAF housing, it is part of the air filter housing you can see in the background of one of the photos.
    Maybe you could try doing a boost leak test?
    cool ride!
    Street Build 420  2
    1991 Mitsubishi Eclipse GST
    fwd · manual · 1G DSM
    Loading...
  3. lglracer
    lglracer Supporting VIP
    287
    34
    Joined Jul 13, 2008
    Sacramento, California
    What ecu is it using? It might have a ECMLink Ecu in it. If that's the case then it is fully tune able. Try opening up the ECU and see whats inside. If not post pictures of it and that will help us.
    Road Race Build 635  1
    1991 Mitsubishi Eclipse GSX
    manual · 1G DSM
    Street Build 589  1
    1990 Mitsubishi Galant GSX
    awd · manual · Galant VR-4
    Street Build 1K  4
    1991 Mitsubishi Galant VR-4
    573  0
    1991 Mitsubishi Eclipse N/T
    manual · 1G DSM
    Loading...
  4. ThunderChild
    ThunderChild Supporting VIP
    3,752
    1,104
    Joined Jan 5, 2012
    Rathdrum, Idaho
    The MAF is there, second picture where the air filter is, it's housed in there.
    I second a BLT. We will need more info on what it is/is not doing to help with diagnosis. Ecu inspection would be a good idea considering they're susceptible to corrosion and blown caps, and this is in a rather exposed application. A
    compression test it, dirt in the engine will be a major concern, especially with the open PCV vent port near the rad-cap
    Also, not a huge fan of the hot-piped turbo-to-tb setup, any kind of intercooler would be beneficial.
    Cool project though, I bet its alot of fun.
    Street Build 1K  3
    1990 Plymouth Laser N/T
    976  8
    1987 Toyota Pickup/Hilux
    awd · manual · Misc Vehicles
    Street Build 2K  7
    1997 Mitsubishi Eclipse Spyder GST
    fwd · manual · 2G DSM
    2K  0
    1992 Eagle Talon TSi AWD
    manual · 1G DSM
    Street Build 3K  10
    awd · manual · 1G DSM
    Loading...
  5. Noel gonzalez
    9
    Joined Oct 4, 2020
    The problem iam having it loses lots of power above 4500 rpm and i get alittle bit of smoke its not blue its got alot of power below 4500 rpm spark plugs were installed yesterday and look black sometimes it dies on me when i go full throttle above 4500 rpm
    Also found this next to the computer
  6. steve
    steve DSM Wiseman
    13,619
    730
    Joined Feb 3, 2002
    Boulder, Colorado
    That's the diagnostic connector where you would plug in your computer to talk to the ECU. Your ECU pictures show a 1G Early DSMLink installed. Did you get a cable to go with it? If not you'll need a replacement from ECMTuning. (the 1G's DSMLink wasn't cable locked since the interface board was part of the install)
    301  4
    2008 Audi TT 3.2 Quattro Roadster
    276  5
    2002 Audi TT Quattro Roadster 225
    273  2
    1992 Dodge Stealth RT/TT
    awd · manual · 3000GT/Stealth
    4K  12
    manual · 1G DSM
    Loading...
  7. Noel gonzalez
    9
    Joined Oct 4, 2020
    No i didn't get the cable with it the guy i bought it from didnt know anything about it either . Is this the cable i need
  8. steve
    steve DSM Wiseman
    13,619
    730
    Joined Feb 3, 2002
    Boulder, Colorado
    That should work.
    301  4
    276  5
    273  2
    4K  12
    manual · 1G DSM
    Loading...
  9. Noel gonzalez
    9
    Joined Oct 4, 2020
    So i just noticed that i have a t in the vaccum line going from the turbo to the waste gate. is this normal?
  10. steve
    steve DSM Wiseman
    13,619
    730
    Joined Feb 3, 2002
    Boulder, Colorado
    Nothing is going to be "Normal" given that it's a sand rail with a 4G63 in it. :)
    Where does the other end of that line go.
    On an original DSM there was a tap on the compressor side of the turbo that ran to the Boost Control Solenoid and then to the wastegate. There was a restrictor in the line before the wastegate to allow the BCS to reduce the pressure that the wastegate saw effectively raising the boost level of the turbo. A line directly between the turbo outlet and the wastegate sets the boost level to whatever the spring pressure is in the wastegate.
    301  4
    276  5
    273  2
    4K  12
    manual · 1G DSM
    Loading...
  11. Noel gonzalez
    9
    Joined Oct 4, 2020
    The other end goes to the side of the compressor just like the picture but there is no solenoid just the vacuum hose. Could that be why iam only getting 5 psi?
  12. randman2011
    randman2011 Proven Member
    320
    126
    Joined Feb 26, 2012
    Indianapolis, Indiana
    I just realized that's the BOV and not the wastegate. No, there absolutely should not be anything teeing off of that. A leak in that line would be hard on your turbo but not cause any performance issues beyond funny sounds.
    However, I do see that there is nothing hooked up to the PCV nipple on the valve cover, which is both not great because it's open to dirty air and not great for any car running MAF like these do.
    Street Build 1K  1
    1998 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Loading...
  13. Noel gonzalez
    9
    Joined Oct 4, 2020
    So just checked and there is a hole in that broken reducer
  14. steve
    steve DSM Wiseman
    13,619
    730
    Joined Feb 3, 2002
    Boulder, Colorado
    Me too, Looking closer at the picture I see that's actually the Blow Off Valve not the Wastegate and that the BOV isn't recirculated back into the intake.
    The BOV should be connected to one of the ports on the throttle body that has manifold pressure (both vacuum and positive) not the turbo compressor outlet.
    The BOV outlet should be connected back to the intake after the MAF so that air that has been counted and included in fueling calculations isn't dumped causing rich conditions. Those BOV's also leak which doesn't help with tuning.
    301  4
    276  5
    273  2
    4K  12
    manual · 1G DSM
    Loading...
  15. Noel gonzalez
    9
    Joined Oct 4, 2020
    So the wastegate connects to the t where the bov goes. I am here looking at the turbo and can't find no vacuum port out of the turbo housing
  16. steve
    steve DSM Wiseman
    13,619
    730
    Joined Feb 3, 2002
    Boulder, Colorado
    How about a picture of the Turbo side of the engine.
    301  4
    276  5
    273  2
    4K  12
    manual · 1G DSM
    Loading...
  17. Noel gonzalez
    9
    Joined Oct 4, 2020
    Here you go
  18. steve
    steve DSM Wiseman
    13,619
    730
    Joined Feb 3, 2002
    Boulder, Colorado
    301  4
    276  5
    273  2
    4K  12
    manual · 1G DSM
    Loading...
    1990TSIAWDTALON likes this.
  19. Noel gonzalez
    9
    Joined Oct 4, 2020
    Yes that goes to the t . So i need that nipple coming out of the compressor connect it to a a boost controller and the other end to the waste gate?
  20. steve
    steve DSM Wiseman
    13,619
    730
    Joined Feb 3, 2002
    Boulder, Colorado
    There are several ways you could set this up.
    Usually it's suggested to make the line between the turbo pressure source and the wastegate as short as possible to reduce any lag in the response that could cause overboosting. Understanding that and lacking any closer port you could use one of the intake manifold ports.
    It's also suggested that the manifold reference for the BOV also be short and directly connected to the intake manifold. There are several ports into the manifold and you should identify them and what they are connected to.
    For example in the third and fourth pictures in your first post there is another vacuum line tee'd to the fuel pressure regulator and some clear tube that runs somewhere else, perhaps a boost gauge. There should be another on the same side closer to the throttle body that is where the BOV is typically connected.
    There are also a couple of ports on the rear of the intake manifold that are currently plugged, the large one used to run to a check valve and was used for a vacuum booster on the brake master.
    301  4
    276  5
    273  2
    4K  12
    manual · 1G DSM
    Loading...
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
