Zeus
- 0
- Jun 16, 2003
My engine has 180k on when it jumped the timing and bent the valves. The new (new to me, but used actually) head is on it's way. I'm down to the head bolts, but I already cracked one (a small crack, hope I am not totally and utterly screwed because of this) either way, I need suggestions for the best method to removing these bolts. I don't have a torch to warm them up, what is the best tool to use (I have the 10mm hexkey on a 1/2 socket with a regular ratcheting socket on top) is there something that attatches to sockets that is like those X shaped tire irons? (something that has handles that would be on either side of the bolt so you can push opposite directions to produce better torque)?
These bolts are really in there. Thanks for the help, Colin.
