Need Help ASAP! Code 32!
TKI
40
Oct 10, 2002
This showed up earlier tonight:
Code 32- EGR solenoid circuit
Possible problems- Harness and connector/ Electric EGR transducer solenoid/ EGR valve/ EGR tube clogged/ Vacuum hoses
I have a couple of questions:
1) Where is this located?
2) How do I fix the problem?
TIA for any help!
what year is your car???? if it is a 95 then its right by the intake...look at the back of the intake manni to the left of the throttle body you will see a long metal pipe that goes to your god damn.....LOL n e ways follow that check all your vacum lines for holes or leaks..... hope that helps
Info that I forgot to add-
'95 Eclipse 420a
just changed the plugs to 1 range hotter NGK's
Thanks for the help, and anyone else have opinions as well? TIA again!
Yep that's the egr no flow code. The system is right where he said it was, and you should check those things. Basicly the flow is not the amount the ECU expects to see. So it's prolly just the clogged tube, but it may be a malfunctioning selonid. I would just block it off and call it a day, but then you would get that code periodicly.
