Sayajin
- 135
- 0
- Jan 11, 2003
Snellville,
Georgia
Hey guys. If you have been reading my past posts then you know that I have a somewhat serious engine oil leak that I need to fix soon. (I have been told my multiple mechanics that there is no danger to the car, just make sure I keep oil in it) However, engine work is like the only thing that I cant do myself or with the help of a friend, so I will be taking it to a shop to get fixed. Meaning I will be paying labor(replacing front cover which of course comes with new oil pump). So I want to get everything out of this one labor cost that I can. So here is what I plan on upgrading at the same time (btw, I am running a Buscher Stage 3 Shortblock, I also have a SAFC):
272/272 HKS Cams
720-750 Injectors
2nd Gen Lifters
and of course new timing belt and front cover with oil pump
(and before anyone says get the kit, Buscher's dont have balance shafts)
While doing these upgrades I have a few questions for you guys.
1. Can I install those big ass injectors without a bigger fuel pump? I didnt think so but I heard that you can. (I am getting a Supra one)
2. If I need to get the fuel pump, do I HAVE to get a AVPC for it? (I read somewhere that with those injectors and big fuel pump I need one in order to make my car run properly. I mean like the pump will push too much into the engine flooding it if I dont? Sorry I am not sure exactly. (this is the big thing)
The reason I ask this is because money is quite tight, but I want to fix the problem ASAP. So If I didint need the Pump I would just install it myself later. However, it will be a while before I can afford a $1000 AVPC so that will kinda put a stop to all this if I HAVE to have one. Then once I do the engine work I plan to get around to doing all of my other mods once my cash is right.
Thanks a lot guys and I would really appreciate the answers to these questions, it is really important to me to get the issues with this engine fixed. I just dont have another 2-3grand to drop into it ASAP if I have to get all of these things at the same time. So it would be nice if I can wait on the fuel pump and AVPC. (the AVPC is the big thing, I suppose a fuel pump is relatively cheap if I have to buy it) Thanks.
*edit* I also wanted to add in that my goal is to hit the low 10sec range and that I plan to add on the FP3065 in the future once I get everything straightned out and get my necessary supporting mods. Thought this may make a difference in peoples suggestions. Thanks.
-Sayajin
272/272 HKS Cams
720-750 Injectors
2nd Gen Lifters
-Sayajin
