Need clutch suggestions for 1995 GSX
ruff
May 5, 2003
I have a 1995 GSX Eclipse and would like to replace the clutch in it.
The car is stock. I plan to buy a clutch kit online and have a mechanic do the install.
Any clutch suggestions would be appreciated.
Thanks
my clutch just decided to slip like a mofo at almost 60,000 miles. If i push down on the gas pedal to hard the RPM's fly up and the speedometer just chills there, and i get to smell that lovely aroma of burnt clutch. So i ordered the Centerforce Dual Friction HD Ballbearing clutch from Road engineering for $375. Most DSM'ers swear up and down on ACT being the best there is, but there are horror stories of ACT's eating up stock trannies, plus the Centerforce has close to stock pedal feel while still being able to handle 2500 lbs
if the car is stock and you don't plan on modifying it all that much, go with a stock strength clutch & pressure plate. i replaced mine with a stocker cause it would have been overkill to put a heavy duty clutch on my next to stock motor (filter), saved a couple hundred dollars. but if you plan on modifying it in the future, it might be best to go with a 2100 or similar.
Hmm I don't remember saying I swear up and down it...also I said ACT 2100
  • For sale 1g coil pack
    Used 1g (91-94) coil pack and bracket. One stud to mount the harness is broken, but still has...
  • For sale 4G63 OEM Balance Shaft Delete Kit
    OEM Balance Shaft Delete Kit $40 + shipping and PayPal fees* includes crank spacerYou must...
  • For sale Evo viii fuel pump
    Used Denso Evo 8 fuel pump. Similar flow to the Walbro 190. Plug n play for 2G's. Been...
  • For sale 2g 2G Hatch Weather Seal ( no rips or tears )
    2G Hatch Weather Seal $45 + shipping and PayPal fees* no rips or tearsYou must be...
  • For sale 2g 2GA Eclipse Fog Lights & Brackets
    2GA Eclipse Fog Lights & Brackets $70 + shipping and PayPal feesYou must be registered to see...
