StxvxC
- 0
- Jan 26, 2023
Mission,
Texas
Hello, this is my first post here and I'm pretty confused.
I recently jumped on a 98' GST and did a whole bunch of research on the car. I'm changing all the old cruddy vacuum lines on it today as the first thing I do to this car. It was running rough and the existing boost gauge showed vacuum was very low so I bought a kit of vacuum line.
I got underneath the car, just now, to take a look and I noticed a bent turbo coolant line facing the radiator. I tried to see where it would connect to the block and didn't notice anywhere. Then I noticed the flywheel and transmission look oddly close to the oil pan. Then a shitty replacement for a bell housing bolt to bolt up to the block.
So all of that combined with no visual of the coolant line hole for the turbo makes me think this might not be the correct block?
Sorry guys I'm 21 and super new to this, I came from the VW/Audi world . Where should I start to check what block this is, if it isn't the original? super confused. TIA!
p.s. I know the block is super dirty, I haven't had a chance to clean any of it. Here for help, advice and guidance, not criticism for things I didn't do to it.
btw they also put coins and like 15 washers to hold the turbo oil line .
