DSMsOwnYourV8
- 370
- 0
- Jan 4, 2008
Denver,
Colorado
Yeah I was thinking he should take it to Jacks' too.
Ay Jayrolla,
I dont know if this post will at all be relevant or helpful for you
but today I was experiement on desensitizing the knock sensor a bit on my car to see the results.
Well anyways the cars dialed in with a sharp tune and id never see more than like 4-8 counts thru the gears on average. Never more than 9 max in any occasion. A lot of people would consider this very conservative and that I could push more.... I dont , I feel its just right for mines as a DD and I dont plan on tuning more aggressive.
But anyways, in experimentation, before I decied to log my car, I loosened up the knock sensor and left it only hand tight and the knock counts remained the same. Then next thing I know its showing up like 43 counts of knock when I was NLTS shifting, therefore it had wiggled loose on me and i was hitten some bad PK with it like that.
Ive never seen my logger ever go to 43 counts of knock under any circumstance, so I figure possibly it being too loose that caused that. Then I tightened it back up ( just to a lower torque spec than originally.)
and all the knock was back to the normal counts Ive always seen.
Then i took it out again, ( burning my arm in the process on a hot IM) and I teflon taped the threads on the KS and put it back in to its original torque specs ( probably a little less ) and all my knock counts were gone and the car was actually a tad bit faster...
I cant say I truely trust these results from the teflon, but I doubt the teflon could keep it from registering real knock that would be threating... I probably will tighten it back up a little bit tighter while leaving the teflon and see what that does, but I must note that I have no more phantom knock in the few places I was getting it before.
Just as a precautious till I experiement with this further, I backed out my timing a few degs everywere thats not under full boost/ WOT just to make sure I dont have knock when cruising or partial throttle while the knock sensor is desensitized.
I normally wouldnt recommend anyone to do this, and I dont feel its something I should be telling people to do on my own behalf, but FWIW perhaps you can dampen your knock sensor a little bit as well and it may help your issue.
) or even at times just from downshifting .I do understand that is over sensitive. There where people that did the jb weld fix and it causes the KS to pick up nothing!! A guy at Jackstransmissions that I know real well did that to his KS and he blew his motor. Good tune but he just was running too much timing with his setup and knock killed his motor. He told me not to try that mod.
Why would you even consider JB welding in a knock sensor? Replace the sensor, or tune the car better.
Did you even read the thread, he was just saying what one of his friends did, he nor I am planning on doing that. And we've been assuming that he's having phantom knock issues and not tuning issues since he's running e85.
You need to stop playing with the knock sensor and just install it properly. That means with proper torque and no JB Weld or Teflon that desensitize it.
Phantom knock is just that. It's not real and it should be ignored because it happens at part throttle conditions only. Ignore it. Simple as that. Do you really care about the loss in timing and power while in vacuum conditions?
Knock that occurs in boost conditions should not be ignored. Installing a knock sensor improperly will inhibit the sensor from picking this up. Foolish in my mind.
I would personally just forget about it completely. 43 knock counts? So what, it at part throttle anyways. Concentrate on WOT knock.
I never said that to you, i was stating for anyone.. Why anyone would think that is a good idea. What's phantom knock? O that's the crap i used to get before i got dsmlink.
Well I do care because the PK will bring itself through the whole RPM band in wot all the way to redline. I get 49 counts and it will hold 20 counts all the way through unless I release the throttle real fast and back on it.
Also when getting the PK it causes the turbo to spool slower due to the low timing. I also dont have that cruisng power like when Im hitting 10psi. The power is horrible when I'm not wot and I have to use more throttle than I would like.
I know thats the one of the best features on dsmlink. Wish I had $800 to waste on dsmlink but I dont. Have another kid on the way.
The ecu only reads to 43, so how are you getting 49?. I get 49 counts .
.While everyone else is out having fun today on this holiday. I will be pulling my tranny to fix the damn fork that broke. Fun Fun Fun!!!
Thanks man. It took me about 6 hours too pull it but that was with a lot of BS inbetween. Now just have to wait on the part. Also have to buy a slave because when the fork broke the slave boot ripped and the boot ripped from the slave itself.
Ohh and I wrapped one layer of teflon tape in front of the hole on the KS and will see if that helps get rid of some PK. I talked to a guy that fixed a pk issue a long time ago and he welded the knock sensor in and that got rid of outside noise. I dont think I will do that though,.
The 1g clutch fork was revised by mitsu awhile back because they where breaking on stock clutch's. My 2600 ACT plate just made it break faster. The new OEM one I bought is much thicker and you can tell they made it stronger. I will be installing it tomorrow. Sucks because it also took out my new OEM slave cylinder and had to get another one.
The 1g KS has a hole on the tip which is the mic pretty much. I put one layer in front of it and around the threads. The tightened it all the way and got a wrench and gave it one good snug. Maybe half a turn and it felt pretty tight already. What is the OEM torque rating if I could get a torque wrench on it?
