habitatguy187
- 3,635
- 253
- Aug 20, 2008
Indianapolis,
Indiana
CAR IS BONE STOCK ASIDE FROM A BOOST CONTROLLER SET TO 14PSI
^^Factory CD player!
Don't mind the mess inside, I was swapping the stock ecu back in since I forgot that my link cable is at a buddies house. Paid $700 for the car, and if you were following my other thread I thought that the alarm system was preventing it to crank since the PO said it was going on and off by itself a few days before it stopped cranking.
Turns out it that the ground on the starter had broken off from inside the clip. Swapped over my old starter from my fwd and voila! Running driving awd with 97k miles on the clock for $700 (~$900 after gas and trailer)
The body is VERY clean, with no rust anywhere that I can see. Vacuum gauge reads -20 but the PO said that the #1 cylinder only showed 110psi on a compression test. There's also a nice tapping noise coming from that area. I seafoamed it but as I figured it didn't help any. Aside from that everything seems to be working great. I've only put about 10 miles on it so far but it's boosting fine at 14psi. The windows work great (), CD player and radio work great too. Overall I couldn't be happier for the price I paid.
