92AWDHX40
Supporting Member
- 13,605
- 1,556
- May 22, 2007
Kalamazoo,
Michigan
What cop are you running my friend got one he had spark issues.
They’re Honda k series coils that I’m going to be runningWhat cop are you running my friend got one he had spark issues.
Should work out well. There’s xfwd Hondas on stock coils without an Ignition box making 1400hpThanks just curious i wonder how that will work for you ill see you in a Norwalk Ohio
This was something I pieced together. The cop plate I got from eBayOh ok can you send me a link.
Hell yea dude can’t wait to see it out!! You guys gunna make the shootout this year??Big update:
Not sure where to begin . So after fighting my old dsmlink tablet not liking the fueltech drivers to read the ecu I had to buy a laptop.
Had an issue with the intake position because of my new water neck. Had to get another fitting for my catch can line
This helped clear the shift cable.
Also got some new goodies from the wife for our anniversary
So fast forward a little. Got the laptop in got a basemap from the tuner and get it loaded up. Car fired up!!!
Had an issue with the tps constantly reading 100% so had to dive into that
Wire broke off in the bulkhead connector
Then took some time in the evening to get some new stickers on the back window
I also have the dash back in the car as well
Couldn’t help but get a pic of it all lit up as well.
Idles tuning has been done. I’ve got to finish bleeding the cooling system, check timing and it’s ready to take for a test drive and start tuning.
Currently on a 8 blade hx40What turbo?
It’s a good possibility we will be there. Hoping testing goes well with the carHell yea dude can’t wait to see it out!! You guys gunna make the shootout this year??
Awesome hope to see you bro!It’s a good possibility we will be there. Hoping testing goes well with the car
The two test drives have been pretty positive. The basemap I was sent is pretty damn spot onLooks like you’ll be out testing it out in no time, good progress per usual!
It was till I noticed the noise coming from the bell housing area so either my converter bolts came loose again or the flexplate bolts came loose.If it’s good enough to make beer runs then sounds like that’s a solid enough starting point in my book.
