Drag Race Build my journey to a 9sec street car
My koyo bearing came in today. To get the one set of bearings pressed off the old gear and get all of them pressed on the new gears
Soo I found a little trick on putting bearings in without using a press. I was a bit skeptical but tried it anyways and it actually worked well.
Going to try this with the other bearings then got to plan a day to swap these things out
Update time:
got a chance this morning to sway my transfer gears. It went surprisingly well for someone that doesn’t know trans work at all LOL. Took about three hours give or take.
Had to go getfluid after I took an atf bath pulling the bottom cover off 🙄. Went for a test drive and all I can say is I’m in love with the whine straight cut gears make LOL
Here’s a little video I took. That whine tho 🤤
What brand/model of tires were you running? 11 years is A LONG time for a set.
They were nitto nt555r drag radials. They were always well taken care of. That’s the only reason I think they lasted. I was planning on changing tires out over winter but after seeing that in the sidewall that plan got moved forward to now LOL
Looks like 26x9.5x16's (I had to zoom in)
Finally got around to throwing these tires on the car. Need to go for a drive and try them out now
something about enkei wheels, Hoosier tires, and wilwood brakes 😍
we have a track rental coming up so I can finally get some more seat time in the car.
Post track rental update:
got my new pb on wastegate pressure!!
made 5 passes: all 10 second passes: 4 were all in the 10.5x. Super happy with how this car is coming. Going to have Kevin jewer turn the car up in the spring and see how she does. Maybe ill
Finally get my 9 second slip. Here’s some pics of the car at the track. Will have more when the wife edits all of hers.
But for now enjoy
