Drag Race Build My 2g dsm second build, this ones going smoother
Morris fab killed it! Just got my low profile trans shifter brackets in! What a nice piece! I’ll post a pic later when I put it on the car!
i got the driver side intercooler pipe welded up today! so thats all done now. this is a picture from today that i took, sorry the exhaust pipe is off, i have to finish welding it up tonight,
tonight's projects for the car.
1) finish welding up the exhaust pipe.
2) making a custom relay/fuse panel. this way i can get rid of everything thats not needed!
in the picture is 10x relays, a small fuse block, and 5x connector strips.
bottom picture is what i will be building******
just got in. so i got the exhaust all welded up and added a bung for the wideband. and got my relay/fuse panel all done as well!
exhaust
and this is the relay/fuse panel
finally! got the engine and trans wiring done, i just have to tidy up the interior harness today
update.
engine harness done
trans harness done
external wastegate done
installed coil on plug and msd box
needs to finish
interior harness (tidy up)
gauges
blow off valve
lower the fuel cell to be level with floor
finish painting the roll cage/interior
shift box (need to order still)
nitrous (dry shot, still need to order)
install softer spring in oil filter housing to lower pressure (ordered it waiting for it to come)
update!!!!
interior harness (tidy up) (DONE)
blow off valve (DONE)
shift box (need to order still) ORDERED A SHIFT 100.1 WAITING FOR ARRIVAL)
install softer spring in oil filter housing to lower pressure (ordered it waiting for it to come) (DONE)
upper lower rad hosed (used piping for custom bends, DONE)
NEED TO FINISH
nitrous (dry shot, still need to order) (NEED TO DO
gauges (MOSTLY DONE)
lower the fuel cell to be level with floor (NEED TO DO)
finish painting the roll cage/interior (NEED TO DO)
Amazing I love it man! I have a couple questions of you don’t mind? How do you get your cold starts to fire right up like that, and what do you do for a living that you learned how to do everything like that? You are a true inspiration and I feel like you have some real talent.
The reason I ask about the cold starts is because I’m running a q45 throttle body on a Magnus manifold and e85 with a gm maf and it seems like every since all that my cold starts take for ever!!!
hey thanks! cold starts are a little tricky LOL honestly i sit in the car and throttle it until it idles, and with e85 i know the problem is even worse, there is no real way to fix it unfortunately. i have my own business as a mobile car mechanic, uniteddiscountauto.com thats my business, but i learned most of my stuff from trial an error LOL and i learned a lot about my dsm from this site! and run speed density its way better!
This is awesome man! Definitely post some videos when you start racing it!!
i cant wait till its done!!! i will post every time i go racing!!! :hellyeah::thumb::thumb:
