I ran across this article, and while we don't usually need the high zinc content, it is GOOD information for high load and flat tappet applications like I deal with on other motor rebuilds.
ZDDP OIL LIST
Please note that the information here came from the http://www.sccoa.com forums ad was compiled in 2015 and reposted from a now dead site by 20psiofevil. SO, that said, do your OWN research. Data sheets are available from the major manufacturers.
Racing Oils
10W30 Lucas Racing Only synthetic = 106,505 psi
zinc = 2642 ppm
phos = 3489 ppm
ZDDP= 3000 ppm
NOTE: This oil is suitable for short term racing use only, and is not suitable for street use.
10W30 Valvoline NSL (Not Street Legal) Conventional Racing Oil = 103,846 psi
zinc = 1669 ppm
phos = 1518 ppm
ZDDP = 1500 ppm
NOTE: Due to its very low TBN value, this oil is only suitable for short term racing use, and is not suitable for street use.
30 wt Red Line Race Oil synthetic = 96,470 psi
zinc = 2207 ppm
phos = 2052 ppm
ZDDP = 2100 ppm
10W30 & 20W50 Valvoline VR1 Conventional Racing Oil (silver bottle) = 103,505 psi
zinc = 1472 ppm
phos = 1544 ppm
ZDDP = 1500 ppm
15W40 CHEVRON DELO 400LE Diesel Oil, conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM, = 73,520 psi
zinc = 1519 ppm
phos = 1139 ppm
ZDDP = 1300 ppm
15W40 MOBIL DELVAC 1300 SUPER Diesel Oil conventional, API CJ-4, CI-4 Plus, CI-4, CH-4/SM, SL = 73,300 psi
zinc = 1297 ppm
phos = 1944 ppm
ZDDP = 1600 ppm
15W40 Farm Rated Heavy Duty Performance Diesel, CI-4, CH-4, CG-4, CF/SL, SJ (conventional) = 73,176 psi
zinc = 1325ppm
phos = 1234 ppm
ZDDP = 1200 ppm
15W40 “NEW” SHELL ROTELLA T Diesel Oil conventional, API CJ-4, CI-4 Plus, CH-4, CF-4,CF/SM = 72,022 psi
zinc = 1454 ppm
phos = 1062 ppm
ZDDP = 1200 ppm
15W40 “OLD” SHELL ROTELLA T Diesel Oil conventional, API CI-4 PLUS, CI-4, CH-4,CG-4,CF-4,CF,SL, SJ, SH = 71,214 psi
zinc = 1171 ppm
phos = 1186 ppm
ZDDP = 1100 ppm
15W40 LUCAS MAGNUM Diesel Oil, conventional, API CI-4,CH-4, CG-4, CF-4, CF/SL = 66,476 psi
zinc = 1441 ppm
phos = 1234 ppm
ZDDP = 1300 ppm
10W40 Valvoline 4 Stroke Motorcycle Oil conventional, API SJ = 65,553 psi
zinc = 1154 ppm
phos = 1075 ppm
ZDDP = 1100 ppm
10W30 Lucas Hot Rod & Classic Hi-Performance Oil, conventional = 62,538 psi
zinc = 2116 ppm
phos = 1855 ppm
ZDDP = 1900 ppm
10W40 Torco TR-1 Racing Oil with MPZ conventional = 59,905 psi
zinc = 1456 ppm
phos = 1150 ppm
ZDDP = 1300 ppm
FULL or partial synthetic Oils
10W30 Valvoline VR1 Synthetic Racing Oil, API SL (black bottle) = 101,139 psi
zinc = 1180 ppm
phos = 1112 ppm
ZDDP = 1100 ppm
10W30 Amsoil Z-Rod Oil synthetic = 95,360 psi
zinc = 1431 ppm
phos = 1441 ppm
ZDDP = 1400 ppm
10W30 Quaker State Defy, API SL semi-synthetic = 90,226 psi
zinc = 1221 ppm
phos = 955 ppm
ZDDP = 1000 ppm
10W30 Joe Gibbs HR4 Hotrod Oil synthetic = 86,270 psi
zinc = 1247 ppm
phos = 1137 ppm
ZDDP = 1100 ppm
15W40 RED LINE Diesel Oil synthetic, API CJ-4/CI-4 PLUS/CI-4/CF/CH-4/CF-4/SM/SL/SH/EO-O = 85,663 psi
zinc = 1615 ppm
phos = 1551 ppm
ZDDP = 1500 ppm
5W30 Lucas API SM synthetic = 76,584 psi
zinc = 1134 ppm
phos = 666 ppm
ZDDP = 900 ppm
5W50 Castrol Edge with Syntec API SN, synthetic, formerly Castrol Syntec, black bottle = 75,409 psi
zinc = 1252 ppm
phos = 1197 ppm
ZDDP = 1200 ppm
5W30 Royal Purple XPR (Extreme Performance Racing) synthetic = 74,860 psi
zinc = 1421 ppm
phos = 1338 ppm
ZDDP = 1300 ppm
5W40 MOBIL 1 TURBO DIESEL TRUCK synthetic, API CJ-4, CI-4 Plus, CI-4, CH-4 and ACEA E7 = 74,312 psi
zinc = 1211 ppm
phos = 1168 ppm
ZDDP = 1100 ppm
zinc = 1519 ppm
phos = 1139 ppm
ZDDP = 1300 ppm
zinc = 1297 ppm
phos = 1944 ppm
ZDDP = 1600 ppm
zinc = 1325ppm
phos = 1234 ppm
ZDDP = 1200 ppm
zinc = 1454 ppm
phos = 1062 ppm
ZDDP = 1200 ppm
18. 0W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,377 psi
zinc = 1621 ppm
phos = 1437 ppm
ZDDP = 1500 ppm
zinc = 1171 ppm
phos = 1186 ppm
ZDDP = 1100 ppm
10W30 Brad Penn, Penn Grade 1 (semi-synthetic) = 71,206 psi
zinc = 1557 ppm
phos = 1651 ppm
ZDDP = 1600 ppm
15W50 Mobil 1, API SN synthetic = 70,235 psi
zinc = 1133 ppm
phos = 1,168 ppm
ZDDP = 1100 ppm
10W40 Edelbrock synthetic = 68,603 psi
zinc = 1193 ppm
phos = 1146 ppm
ZDDP = 100 ppm
10W30 Royal Purple HPS (High Performance Street) synthetic = 66,211 psi
zinc = 1774 ppm
phos = 1347 ppm
ZDDP = 1500 ppm
5W30 Klotz Estorlin Racing Oil, API SL synthetic = 64,175 psi
zinc = 1765 ppm
phos = 2468 ppm
ZDDP = 2100 ppm
Break in oil
10W30 Comp Cams Break-In Oil conventional = 51,749 psi
zinc = 3004 ppm
phos = 2613 ppm
ZDDP = 2800 ppm
30wt Lucas Break-In Oil conventional = 49,455 psi
zinc = 4483 ppm
phos = 3660 ppm
ZDDP = 4000 ppm
Marty
ZDDP OIL LIST
Racing Oils
zinc = 2642 ppm
phos = 3489 ppm
ZDDP= 3000 ppm
zinc = 1669 ppm
phos = 1518 ppm
ZDDP = 1500 ppm
zinc = 2207 ppm
phos = 2052 ppm
ZDDP = 2100 ppm
zinc = 1472 ppm
phos = 1544 ppm
ZDDP = 1500 ppm
zinc = 1519 ppm
phos = 1139 ppm
ZDDP = 1300 ppm
zinc = 1297 ppm
phos = 1944 ppm
ZDDP = 1600 ppm
zinc = 1325ppm
phos = 1234 ppm
ZDDP = 1200 ppm
zinc = 1454 ppm
phos = 1062 ppm
ZDDP = 1200 ppm
zinc = 1171 ppm
phos = 1186 ppm
ZDDP = 1100 ppm
zinc = 1441 ppm
phos = 1234 ppm
ZDDP = 1300 ppm
zinc = 1154 ppm
phos = 1075 ppm
ZDDP = 1100 ppm
zinc = 2116 ppm
phos = 1855 ppm
ZDDP = 1900 ppm
zinc = 1456 ppm
phos = 1150 ppm
ZDDP = 1300 ppm
zinc = 1180 ppm
phos = 1112 ppm
ZDDP = 1100 ppm
zinc = 1431 ppm
phos = 1441 ppm
ZDDP = 1400 ppm
zinc = 1221 ppm
phos = 955 ppm
ZDDP = 1000 ppm
zinc = 1247 ppm
phos = 1137 ppm
ZDDP = 1100 ppm
zinc = 1615 ppm
phos = 1551 ppm
ZDDP = 1500 ppm
zinc = 1134 ppm
phos = 666 ppm
ZDDP = 900 ppm
zinc = 1252 ppm
phos = 1197 ppm
ZDDP = 1200 ppm
zinc = 1421 ppm
phos = 1338 ppm
ZDDP = 1300 ppm
zinc = 1211 ppm
phos = 1168 ppm
ZDDP = 1100 ppm
zinc = 1519 ppm
phos = 1139 ppm
ZDDP = 1300 ppm
zinc = 1297 ppm
phos = 1944 ppm
ZDDP = 1600 ppm
zinc = 1325ppm
phos = 1234 ppm
ZDDP = 1200 ppm
zinc = 1454 ppm
phos = 1062 ppm
ZDDP = 1200 ppm
zinc = 1621 ppm
phos = 1437 ppm
ZDDP = 1500 ppm
zinc = 1171 ppm
phos = 1186 ppm
ZDDP = 1100 ppm
zinc = 1557 ppm
phos = 1651 ppm
ZDDP = 1600 ppm
zinc = 1133 ppm
phos = 1,168 ppm
ZDDP = 1100 ppm
zinc = 1193 ppm
phos = 1146 ppm
ZDDP = 100 ppm
zinc = 1774 ppm
phos = 1347 ppm
ZDDP = 1500 ppm
zinc = 1765 ppm
phos = 2468 ppm
ZDDP = 2100 ppm
Break in oil
zinc = 3004 ppm
phos = 2613 ppm
ZDDP = 2800 ppm
zinc = 4483 ppm
phos = 3660 ppm
ZDDP = 4000 ppm
Marty
