CrackedDSM
- 2,648
- 1,371
- Dec 17, 2009
Pensacola,
Florida
Hey guys, I'm trying to plan ahead for everything on my Talon that I need, and I'm up to the air conditioning portion. The car has an ETS front mount on it, and two mishimoto slim fans that I plan to ditch ASAP. Because the previous owner informed me it had an issue with overheating around town, even without A/C. That's hard for me to believe because it has an aftermarket aluminum radiator in it, and my old 1G with a VRSF front mount had zero issues with cooling even with a leaky HG/using coolant issue. It only overheated when it lost a certain amount of coolant.
So, my request to you 1G guys who have decent(350+awhp) setups and kept your A/C and powersteering with front mount intercoolers, in a hot(preferably tropical or like Arizona climate) area. How is your setup? Did you have to do anything special? Do you have stock fans? How are temps with your A/C on? Just your general cooling setup and information, even if its "I have a FMIC, A/C, and did absolutely nothing and temps are great" with some pictures is fine. I just want to get an idea of what I'm in for/what I need to plan for. It's been a very long time since my 1G.
For reference, the setup on the car before was a tubular T3 manifold/custom 02 housing, with no kind of heat shielding and sticking kinda close to the radiator. The setup going in now is gonna be Mitsubishi flanged bolt on(FP Green) with all the OEM heatshielding(for both turbine housing/02 housing, and manifold) so I think that'll help a ton. But still, all experience and comments/setups welcome.
