yhype
- 332
- 11
- Nov 3, 2002
Thurmont,
Maryland
Does anyone know where Mitsu's 2.6L G54B engine is found? And if it is an V6. inline6, or what type of engine it is. thanks
Note: This feature currently requires accessing the site using the built-in Safari browser.
STARION said:Yeah this motor is found in all sorts of cars (4G54B). It was the ONLY motor that came in starions/conquests throughout there whole production run (for the US market). It essentially is a truck type of motor, with relatively long stroke. The stock rods are TOUGH, and have taken upwards of 700hp with some shot peening. The stock pistons are junk, The stock heads like to crack. The biggest obstacle for this motor is its throttle body injection, which is a large limiting factor. There is tons of info on all this, just go over and read up on the starion/conquest forums. Oh, and there are lots of parts available for this motor (you don't have to get anything from australia.)
blue1 said:You cant put a decent head on these they are timing chain drive cam, they seem to be not a very great motor. Stock they put out 70KW and a common flaw with them is they crack the block between the welsh plugs and i do mean this is common!! i had one in my triton ute (mighty max to you guys) they are gutless and boy do they suck juice! they run a real heavy flywheel in the commercial set ups which gives them a bit of torque but thats about all you can say good about them!. They also are the wide block 13 1/4" between the bell housing bolts.
