98gstbrad
- 63
- 0
- Oct 11, 2011
waco,
Texas
Ok so heres the rundown. I have a missfire when i hit over 5 psi of boost, car is all stock and here is what i have come up with for the reason for problems. I know i have a small boost leak in my uicp (upper intercooler piping) and at first i could not boost at all so i pulled the plugs. They seemed to be in need of a change so i replaced them with the proper ngk plugs gapped to stock 32. Then i could hit 5 psi after that so then i got the code scanned again both times it has said cylinder 4 misfire. So to make sure it was the wire i moved the 4 wire to 2, the 2 wire to 4, and left the 3 wire and 1 wire now. Its still having the same problems but it wont set a misfire code. What could it possibly be and i Do not think it is the coil packs please give me some ideas and when i say stock car i mean stock unmolested in all ways.
