MorrisonFab
Supporting Vendor
- 268
- 824
- May 28, 2017
Johnson Creek,
Wisconsin
Full flow 5/8" drain kit for 14b/16g/FP bolt-on turbos where the factory drain doesn't quite work or if you would rather slide a hose off during turbo removal instead of dealing with gaskets.
Each fitting is slightly angled toward each other for an easier bend with the high temp hose and the oil pan fitting is angled upwards to promote more oil drainage out of the line.
Includes the fittings, pre-trimmed hose, clamps, turbo bolts, and self sealing oil pan bolts with o-rings under the bolt heads.
We sneakily added 5/8" drain kits recently to cover basically all DSM and Evo turbo drain options and we were really happy to see this work out so well.
$99 plus shipping
A big thank you to John Hanlon at DSMotorsport for the test fitting, feedback, and constant support!
$99 plus shipping
