1. Join the Community!
1G MFI Relay woes
Posted by 2JZT100, Jun 14, 2019
Please Support Kiggly Racing
Please Support Southbay Fuel Injectors
  1. 2JZT100
    2JZT100 Probationary Member
    Joined Jun 11, 2019
    Las Vegas, Nevada
    Hello everybody, I just picked up a 1G DSM. It's a 1990 1.8 Manual Base Model. I've been trying to get it to run but the fuel pump is not turning on. There's not even power at the fuel pump connector. So I followed some of the things the forum said, and it brought me back to MFI relay. The relay itself looks like its been messed with before, so im trying to figure out if its the right one for this car. On it says E8T06975 and bottom 4 digits 9807. But also, is there a fuse that's with it? When I got the car there were whole lotta fuses just missing, even including an ignition fuse. So maybe the previous owner pulled the fuse also? I'm not sure, i'm completely new to this DSM World.
    But Thank you to anyone who reads this!
  2. dustyboner
    dustyboner DSM Wiseman
    1,055
    385
    Joined Mar 13, 2016
    abq, New Mexico
    if you want a copy of the service manuals here are the download links:
  3. luv2rallye
    luv2rallye DSM Wiseman
    7,782
    691
    Joined Jun 7, 2003
    Minneapolis, Minnesota
    Know that on the 2.0L engines (all 1g and 2g turbo, but not 2gNT), the ECU activates the fuel pump only when the engine is rotating getting CAS pulses (not with just key on). Not 100% sure but your 1.8L may be the same way.
    3K  0
    1999 Mitsubishi Eclipse GST
    14.200 @ 95.000 · 2G DSM
    Loading...
Share This Page
Boosted Fabrication ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing Raven Fabrication RixRacing RockAuto RTM Racing SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
