1. Join the Community!
Street Build Methed-up Eclipse
Year:
1996
Model/Trim:
Mitsubishi Eclipse GSX
Please Support STM Tuned
  1. cornboy
    cornboy Probationary Member
    21
    Joined Feb 28, 2020
    Manhattan, Kansas
    Street Build 173  3
    1996 Mitsubishi Eclipse GSX
    awd · manual · 2G DSM
    Loading...
  2. cornboy
    21
    Joined Feb 28, 2020
    Manhattan, Kansas
    First week, there's an electrical short in the ignition system, which could be pretty much anything in the car minus the tailllights, so tomorrow I plan on replacing the ignition switch to see if that solves it and if not, just start f***ing around and pulling fuses. If my poor attempts at diagnosing are insufficient, I plan to take it to a shop and see if they can untangle this rat's nest.
    Street Build 173  3
    Loading...
  3. cornboy
    21
    Joined Feb 28, 2020
    Manhattan, Kansas
    Took the car into the shop on Wednesday, just got it back today. I wouldn't say it runs like a dream, but it at least runs and drives. Decided I'd try my luck and take it for a drive around town and within about 30 minutes it started idling at 4000rpm and overheated. Got a friend to bring me some water and filled up the radiator before heading home. Still waiting for a blow off valve flange so I can mount the Greddy BOV that fredom dsm sold me. Thinking about buying a larger radiator and new hoses to go with the BOV and intake filter that I need to buy as well.
    Street Build 173  3
    Loading...
  4. cornboy
    21
    Joined Feb 28, 2020
    Manhattan, Kansas
    Finally got an intake filter and some new vacuum lines so the wastegate actually works. Now instead of fuel cutting at 4500rpm because I'm at 15psi of boost, I'm getting at maximum 5-6 psi of boost. Beyond that, I also ordered new brake rotors and pads cause the ones on it felt sloppy and warped, beyond just visibly being rusted. It looks like it'll be back in the shop next Monday to get the brakes mounted, the blow off valve put in, and not f***ing up the turbo with compressor surge.
    Street Build 173  3
    Loading...
  5. cornboy
    21
    Joined Feb 28, 2020
    Manhattan, Kansas
    Brakes got put on, just normal Duralast brakes. Finally got the blow off valve installed, and hooked up. I'm pretty sure I have a boost leak somewhere, but for now I'm not having compressor surge.
    Street Build 173  3
    Loading...
  6. cornboy
    21
    Joined Feb 28, 2020
    Manhattan, Kansas
    Both a lot and not a lot has happened. I was having an issue with my car running poorly after about 40mph, where it would either lean out, or become too rich. I re-ran the vacuum lines for the blow off valve and waste gate according to the diagrams listed here: https://www.dsmtuners.com/threads/taboo-speed-shop-vacuum-diagram-and-removal-for-1g-and-2g.198327/
    This didn't solve my problem, so I'm faced with a couple of potential solutions to this. I could do any of these: replace the spark plugs, replace the O2 sensor, replace the fuel pressure regulator, try running it without an air filter, try running it with a different air filter, run it without a blow off valve, run it with a different blow off valve. But ultimately I don't know if any of these would work, the person I purchased it from mentioned a bad tune, and while that might be the case, I don't know how to verify that versus just poor maintenance.
    So since I will be moving to my own house with a garage and will have a job that could support it, the plan as of right now is to just replace the spark plugs in case thats an issue, clean the mass air flow sensor, and if that doesn't fix it, either drive slowly and carefully during the move, or have it towed flat bed to its new destination. From there, we can go ahead and tear the car down, have the engine looked at, and potentially rebuilt with part that I actually know are in it, install a new clutch and flywheel, have the transmission serviced, have all the differentials inspected and serviced if need be, and then actually start trying to repair some of the shoddy wiring though the engine bay.
    Street Build 173  3
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
