90laserRSfwd
- 1,412
- 84
- Mar 5, 2007
Elizabethtown,
Pennsylvania
Long story short, I need someone with a 1g (FWD or early AWD) that has the small brakes (single piston OEM calipers, rotor size, and stock mounting, basically stock small brakes), to post a picture, with the measurement from the hub center (where the axle comes threw the hub), to the outer edge of the caliper (where the inside of the wheel would make contact with caliper if mounted).
I'm trying to sort out whether or not, a certain wheel will fit my car if I swap from twin piston brakes to the smaller single pistons. I need these measurements front and rear. Meaning stock rear brakes and single piston front brakes. My car isn't close to me, and being as such, I can't physically install the wheel onto my car. Thanks in advance.
See attached pic to see what mean by "outer caliper and inner wheel". The gap that exists in that pic (distance the brake caliper is from hitting the wheel). I need a measurement from the hub center to the caliper's outer edge. (trying to see if I can go to a wheel that's smaller, diameter wise).
