NAT01
- 194
- 0
- Jun 26, 2003
PennsylvaniaUS
My 94' ka24e 4-cyl hardbody will not start up! It turns over fine, but will not come to life. I've replaced the spark plugs, cap, rotor, and wires. They were changed this past summer. The truck does have spark, so the coil is alright(i'm guessing). The ends of the plugs do seem a little blackish. The truck did give off a bucking/hesitation before it finally just died on me. Any ideas on what I might be able to check prior to taking to the mechanic and getting ripped off? The fuel pump does kick on too. That was replaced last year as well with the fuel filter. After I crank it for a while(10 sec) I do smell a gas odor. Do you think it could perhaps be the ECU? I know our cars show similar problems and many times it's the ECU that's the culprit. Think that could be it? Thanks for any help you may be able to voice.
