MattiaFTW
- 69
- 9
- Dec 1, 2021
Ede, The Netherlands,
Europe
I have a Mitsubishi eclipse 2g. And um running the Evo 4-9 plugin adapter. Which is pretty much plug and play. All sensors work. Got fuel pressure. Injectors working ( deka 875cc). IAT working. Lamba working. Like everything functions and gives normal values.
My problem start with all the timing things. For some reason it will not start. I have tried multiple trigger angles. Measured it with a timing light, tried over and over. Checked the correct polarity. And it just doesn't work, at least not consistently. Got it to work for like 30 seconds with settings
Frist thoot trigger angle : 80
Ignition lock : 0
Polarity of trigger : rising
Polarity of home : falling
It ran for a bit. Then automatically shuts off. Checked all te logs. Lamda was a bit high. But no weird things. Tried to start it again with the exact same settings. Nothing. Tried a million different values and thing but it just won't work.
I suspect something really weird is going on with the trigger signal
Trigger logger shows a 2 green 2 orange. Except the time it ran. All green with no errors until it started to die on its own.
I attached some pictures below and i really hope you know or suspect what the problem is.
Thank you so much for taking the time to read and hopefully help me with it.
Greeting Mattia
Ignition lock : 0
Greeting Mattia
