Maximum efficient boost on small 16G?
Antilles
305
Aug 25, 2002
Savage, Minnesota
I was wondering what psi the small 16G starts to run out of breath at, and where it no longer makes "economical" power. 24? any higher than that? I am going to be maxing out my 16G soon here, and theres no point in wasting a dyno run by running more boost than what will actually make any power.
And does anyone know how much power has been made on the 16G without nitrous? or is that question against the rules :shhh:
chris
what injector size (minimum) could you run those kind of numbers with, if you, of course had an upgraded fuel pump.
(I have walboro 190 Re-wired, and 510s, I have no AFC and a small 16G w/fmic. could I try 23-25 psi @ the track on race gas without leaning to the point of hurting things?)
I probably hit about 25psi on race gas with stock injectors and an un-rewired pump with my 16G. Not sure if I hurt anything though. ;)
I will have a wired 190, 550s, AFC and VPC. If that thing'll make 26psi, then thats what go for.
