Mark4g63t
- 294
- 5
- Jan 21, 2010
Minneapolis,
Minnesota
Hey guys. Just going to make a list of some of the things the car has been through and what all i've changed on it along with the up coming build I am in the process of doing with a goal of ~700awhp. I should have lots of pics.
So to start it off. I got the car completely stock besides a Greddy BOV when I was 17, now 23. It was a FWD Talon TSI. Drove it for a little bit before the stock turbo went out and I replaced it with a new one. After that the #3 rod went through the block and I began my first rebuild.
That build consisted of:
6 bolt block with 2g head
1g rods 2g pistons stock crank
16g internally gated
650cc FIC's
DSMLinkV3
The 16g turbo
Engine bay back then
How it was always treating me..http://www.dsmtuners.com/attachment...8/?temp_hash=c64c5eee28ef6b3d658bc651a8234e60
After that I was starting to get into the whole boost thing and learning more about my addiction that had taken ahold of me.
I soon had to have more power and a decent looking setup. So I got.
VRSF FMIC
TD06 20g
1g BOV
FIC BlueMax 1050's
AFPR
-AN Fuel Filter
Did a little bit of a wire tuck deleting all the emissions stuff and then the AC soon after and PS down the road.
Hid the fuse box down in the passenger wheel well area.
FMIC Install
How it was starting to look...Messy
Made a switch to run E85
Then I burnt an exhaust valve, so I got the head rebuilt and slapped it back on.
I couldn't stand only being able to do 40+mph rolls any longer and decided it was time for an AWD swap. I did some research and knew some people that had done the swap before and soon found myself searching for a parts car to steal the parts from. That in itself was a total joke and a waste of time. Car ended up being in Iowa and I was told it was an AWD 5 speed, however when I got there it was a AWD Auto. I still took it home and sold the trans and t case. for a 5 speed one and I kept the:
Gas tank
Rear subframe with the bolts
rear axles
LSD Diff that I ended up swapping the gears out of it for 5 speed ones
driveshaft and the hangers
Parts car
Rear diff pinion and ring gear for a 5 speedhttp://www.dsmtuners.com/attachment...3/?temp_hash=c64c5eee28ef6b3d658bc651a8234e60
During the swap
And thats where I'm ending it for now as I need a break
650cc FIC's
DSMLinkV3
The 16g turbo
VRSF FMIC
TD06 20g
1g BOV
FIC BlueMax 1050's
AFPR
-AN Fuel Filter
FMIC Install
Gas tank
rear axles
Parts car
During the swap
