tunernewb92
- 342
- 74
- Sep 10, 2008
North Canton,
Ohio
Ok so we replaced the exhaust, broke a bolt and had to pull the turbo completely out of the car to get the bolt out. We also replaced the 1g mani with a 2g ported mani. When we got it all bolted back up and cranked it, we discovered that it was leaking on the back drivers side of where the manifold and turbo connect. Forgot to put copper RVT on it DUH... so off it came again. This time when we took it off a bolt sheared off on the front drivers site of the four bolts that hold all that together. We tried drilling, tapping, hammering, nothing could get it out, but when the car was first bought there was a missing bolt in the same spot and it didn't leak. Anyway, we put the copper RVT sealant, a new generic gasket (that is basically a flat plate with a hole in the center) and put it back on. Waited about 30 minutes and cranked it up. Ran the crap out of the car for like 15-20 minutes to hear the new Apexi N1 exhaust, brought it back and killed it. Yesterday afternoon it developed a leak in the same place again. I don't think this is from not having that front bolt because its leaking in the back on the same side where there is a bolt. Did we not wait long enough for the RVT to dry maybe, or is there some other gasket that we need to be using, like the 2g version, should we just use grease and let it harden up and make its on gasket instead of RVT. We need to get this fixed because obviously the turbo won't spool as fast and as hard with an exhaust leak.
