dwdsm
- 564
- 27
- Apr 28, 2005
Scenery Hill,
Pennsylvania
So I'm doing a complete rewire of the 2G to get rid of the brittle 23 year old harness. I am also making the system have one fuse/relay box. I purchased an Eaton VCM and ran into a problem.. Normally ignition and all the things it powers are high side switched. The Eaton is set up for a low side switch. Anyone see a problem flipping my ignition into essentially a grounding bar therefore a low side switch? The relays would then power everything else in their usual way so I can't find a flaw in this plan but would like other opinions. Starter signal to the ECU would then just come from the high side of the starter relay instead of straight from the ignition.
