1. Join the Community!
MAF Translator
Posted by Laoz4G63, Oct 7, 2005
Please Support STM Tuned
  1. Laoz4G63
    Laoz4G63 Probationary Member
    12
    Joined Aug 4, 2005
    Daytona Beach, Florida
    I have a 2g car but I am swapping 1g (6 bolt) into it. Am I suppose to get a maf translator for 1g or 2g? How about the gm mas? Which is better 3" or 3.5"? Appreciate your help.
  2. gsx951
    gsx951 Proven Member
    848
    12
    Joined Dec 30, 2002
    townsville, Michigan
    Unless your running a fairly large turbo, your stock air meter is more accurate than the GM unit.
    To answer the question 2G and 3"
  3. Laoz4G63
    12
    Joined Aug 4, 2005
    So, does that mean that I only need the maf translator? I can use my 2g mas?
  4. nickrule99
    nickrule99 Proven Member
    502
    Joined Jun 14, 2003
    Greenfield, Massachusetts
    Why exactly do you need a gm mas?
    The stock 2g MAS will be good enough for around 400hp.
    But, I guess that wasnt the point of this thread.
    If you must get one, get the 3" version.
    And you'll need to get a Maf-T for a 2g
    Edit:
    I just read your post again, and I think you might be confused about the differences between a GM maf and a DSM maf. You dont need to order a translator with a 2g mas, with a 6 bolt swap your still going to be using the same intake piping. The only reason you'd order a maf translator is if you were running a GM unit.
    -Nick
    313  0
    1995 Eagle Talon TSi AWD
    manual · 2G DSM
    Loading...
  5. Laoz4G63
    12
    Joined Aug 4, 2005
    I want to vent my bov into atmosphere. I also heard that it is much easier to tune. So let me get this straight.
    I have a 2g mas and I don't need a gm mas.
    But, I do need the translator to vent into atmosphere and ease of tuning.
    or
    I don't need the translator period because of the 2g mas.
    Please help.
  6. nickrule99
    502
    Joined Jun 14, 2003
    Ok..
    So your going to need to buy a Translator (for a 2g) and a 3" GM MAS.
    Its going to cost you around $250 to vent your BOV.. it is really worth it?
    Plus your going to need to hack your UICP in order to make room for the MAF, just something to think about.
    -Nick
    313  0
    manual · 2G DSM
    Loading...
  7. tstkl
    tstkl Proven Member
    3,827
    48
    Joined Feb 10, 2005
    SoCal, California
    dude, just search for your answers some more, this question has been answered like a million times....
    the maf tells the engine how much air is passing by it, if you vent your bov after the maf has counted the air your venting, there is NO way to tune for that... the maft can ONLY be used if you have a gm maf, and you can only vent if you put the maf AFTER the bov... that way its not counting air that will not be going in the engine and screwing things up...
  8. Booster-Shot
    Booster-Shot Proven Member
    1,187
    4
    Joined Jul 21, 2005
    Napa, California
    I always hears the 2g maf is good for 400hp. How about the 1g? :confused:
    Venting is something I would love to do with my car but it just doesnt seem practical. Im sure if you buy an aftermarket intake and uicp your car will sound great.
  9. redhyena69
    redhyena69 Proven Member
    57
    Joined Feb 25, 2004
    Dae-Gu,South Korea, Asia
    He has 2 G but he's gonna awap the motor with 1G, so he wanted to know what version of
    MAFT for his motor swapped 2G.
    Reason why he wanted MAFT and GM MAS are 1. BOV (vent) 2.Feul Tune.
    I think, He did some search already but couldn't find the answer for motor
    swapped case like his.
    He might have to spend $250 and hack UICP, He might already knows that.
    Some people think Vent BOV and simple fuel tune for $250 is too much
    some people think don't. Simple SAFC is $250 also.
    He might know that already and with same $250 he chose MAFT and GM MAS.
    It's just his choice, don;t be Harsh
  10. timloomis
    timloomis Proven Member
    930
    13
    Joined Jan 28, 2003
    duncan falls, Ohio
    the maft doesnt just allow you to vent.it also has fuel tuning.so its not 250 bucks just to vent.you can compensate for bigger injectors,add fuel for nitrous,etc..
    416  0
    1992 Eagle Talon TSi
    14.796 @ 93.970 · 1G DSM
    Loading...
  11. redhyena69
    57
    Joined Feb 25, 2004
    :thumb: THE BEST Answer~!
  12. Laoz4G63
    12
    Joined Aug 4, 2005
    I knew how much it will cost me and where the bov suppose to go and all that.
    My main concern was the wiring of the maf translator and the compantibility of the gm mas. I didn't think that my 2g mas will work with 2g maf or 1g maf.
  13. speedmaster747
    speedmaster747 Proven Member
    170
    Joined Sep 20, 2005
    Miami, Florida
    What about that new MAF translator plus????
    MAP sensor instead of AFM....???
    Anybody have info on this!??? :dsm:
    255  0
    1993 Mitsubishi Eclipse GSX
    manual · 1G DSM
    Loading...
  14. Quasimondo
    Quasimondo Proven Member
    2,662
    66
    Joined Jan 17, 2004
    Washington,
    The translator for the 1G and 2G is the same device. The only difference is the the connector used to plug into the vehicle's harness and the DIP switch settings used which are explained in the instructions (which is also available online here).
    You don't seem to be the kind who wants to hear my personal opinion of the translator so I'll keep that thought to myself, though from people i know who use the MAFTPro, they love it, so I can only assume that the Translator Gen2 is much better than the original one.
  15. speedmaster747
    170
    Joined Sep 20, 2005
    Miami, Florida
    I had prior experience with GEN 1 translator. I didn't like that much!
    I hope the new one is better!
    255  0
    manual · 1G DSM
    Loading...
  16. speedmaster747
    170
    Joined Sep 20, 2005
    Miami, Florida
    BUMP!
    I gues no one has used the new translator? :dsm:
    255  0
    manual · 1G DSM
    Loading...
Share This Page
ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RixRacing RockAuto SouthBay Fuel Injectors STM Tuned Track Decals Track Sculptures VR Speed Factory
