safirenside
- 170
- 0
- Jan 28, 2011
houston,
Texas
My car died the other day while I was driving so I tested the supply voltage to cam and crank sensor and I was reading .72 volts. The cam is suppose to read around 12 volts and the crank around 9volts, also I can not connect to the obd2 on my lap top its says it has no power. Is my ecu bad?
