tay97gst
- 476
- 32
- Dec 20, 2011
Plaistow,
New_Hampshire
I replaced the master clutch cylinder because it was leaking onto my carpet. Before i replaced it the clutch was stiff but felt good. Now the clutch has very little pressure and is very easy to press. Also, when i release the clutch it slows down slightly before making it all the way to resting position. I've bled it using the slave cylinder bleeder valve but it still is the same stiffness. Help
I might as well add that when in gear, theres very little room between having the clutch pedal being all the way down and then the engagement point. I would say there's only about 1/2-1inch from the floor to engagement point which feels so weird. There used to be a lot more distance between these two.
http://www.youtube.com/watch?v=vYJxQyjIhUw&feature=player_embedded
I watched this video but whether im too tired or too stupid I couldnt understand how to apply this to my situation. Can someone put his steps into lamens terms for me?
